a slight miss fire
Old Mar 20, 2007 | 05:40 PM
djmillsy's Avatar
djmillsy
Fife Radge
Default a slight miss fire
right got the new engine in theres no air leaks in it but when you go on to full boost the car stutuers then back fires anyone any ideas whats happening
Old Mar 20, 2007 | 05:43 PM
KSA-Cossie's Avatar
KSA-Cossie
Plugs and or gap ?
Old Mar 20, 2007 | 05:47 PM
SafeChav's Avatar
SafeChav
Boost limit on the ECU?
Old Mar 20, 2007 | 05:51 PM
djmillsy's Avatar
djmillsy
Fife Radge
its running 0.5 bar so i cant see it being the limiter
djmillsy's Avatar
djmillsy
Fife Radge
would this happen if the amal valve is connected wrong
Old Mar 20, 2007 | 06:04 PM
SafeChav's Avatar
SafeChav
Nah doubt it!
Would probably be worth while going back through the other thread you had going
Did you try a new dizzy?
Old Mar 20, 2007 | 06:34 PM
djmillsy's Avatar
djmillsy
Fife Radge
aye its a new dizzy were goingto reset the timing i did adjust thhe mixing screw on the throttle body tho
Old Mar 20, 2007 | 06:48 PM
SafeChav's Avatar
SafeChav
The screw on the throttle body is just the idle speed.
Timing is a good move
Old Mar 20, 2007 | 06:57 PM
djmillsy's Avatar
djmillsy
Fife Radge
im going to do that the night ill let you know hows it goes if you just ease the turbo in theres no prblem just when its open full
Old Mar 25, 2007 | 08:51 AM
djmillsy's Avatar
djmillsy
Fife Radge
took its out this morning got her hslf way work and it was missfiring and lost power the boost gauge was wobbling about. then under deceleration i noticed a wee bit of smoke out the back could the turbo be shagged
Old Mar 25, 2007 | 08:31 PM
SafeChav's Avatar
SafeChav
Shouldnt misfire because of a turbo!
Old Mar 26, 2007 | 04:44 PM
djmillsy's Avatar
djmillsy
Fife Radge
yeah no that i think there a pipe off somewhere
Old Mar 26, 2007 | 04:59 PM
SafeChav's Avatar
SafeChav
If you had a significant air leak the car wouldnt start and idle!
Old Mar 26, 2007 | 07:19 PM
djmillsy's Avatar
djmillsy
Fife Radge
well you got to keep the throttle on or it cuts out it wint idle it done it before when the mixture screw fell out
Old Mar 26, 2007 | 07:20 PM
SafeChav's Avatar
SafeChav
I'd start from scratch personally, rip everything out of the engine bay and inspect every hose etc before re-fitting, but thats me
Old Mar 26, 2007 | 07:23 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
personally i would check the limiter,,as safechav said,or believe it or not,mine was doing similar things,till i re-wired my pump with clean fresh conections,full power and no dry joints in the lead-to-post connections, and alls well, until my limiter pops a biggun,to tell me off.
Old Mar 27, 2007 | 01:59 AM
oakey dokey's Avatar
oakey dokey
i had this sort of problem fine on idle then when i booted it started to miss fire turned out to be a fooked ht lead
Old Mar 27, 2007 | 05:32 PM
djmillsy's Avatar
djmillsy
Fife Radge
thats what im planning to do as i say i heard a hose pop off and then no power and backfiring. its getting booked in for a set up in the next two weeks my car my pals car and his pals car are all doing the same thing
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
gambo08
Feb 4, 2016 10:49 PM
Fil
Sep 30, 2015 12:08 PM
xrmalin
Sep 13, 2015 06:52 PM
