help!!! ive put petrol in my escort diesel van!!!!
how much? i put about 3 quid in by mistake once, put a tenners derv in to dilute and it was fine. just take the feed pipe off the fuel rail and keep pumping the plunger, or take the pipe off the tank and drain it.
dont bother,...
just brim it with diesel,...will be ok...
unless you already brimmed it with petrol.....mong,..lol...
in that case just undo the fuel pipe from botom of tank, into bucket or similar, then brim it with diesel
remove the pipe and let it all come out
diesel needs lubrication so if you put petrol in it it fucks this up
on newer motors even the sniff of petrol can cause huge amounts of damage to the fuel system so better to have to fork out a few quid now than a few hundred later on
I would just feel it with diesel, some petrol in diesel will do no harm.
My old TDi Golf failed its NCT ( the irish MOT) because of emmissions,
put a fiver of petrol in 15 quids woth of diesel and it passed.
If you live in a fuck off cold area (Norway or somewhere) it can help to stop the diesel from freezing, or so I've been told, maybe wrong
Originally Posted by rob v
Originally Posted by rst in progress
bloody pump handle was black and stuck £25 worth of ultimate in started to get a little blue smoke?
or the cover ?
or the cover ?
the coloured part is just a plastic sleeve above the main handle
my apprentice put 20 quids worth in a transit once
filled it with diesle and it was fine after a week
kept staling for a while at junctions ,so every time a quater tank was used i topped it up so it was getting diluted each time
If it has no cat it will be fine, I did this but with £20 in my escort diesel, and it smoked a bit power went up and down and after two full tanks of diesel was perfectly ok, took pump along to a CAV centre where freind works and he says does not harm pump at all, and as he pointed out it is a common trick to put some in artics during winter to stave off fuel freeze.
Originally Posted by kevandalice
you realise you can get BP ultimate diesel don't you?
you didn't put that in did you?
all sorted, reallywasn't feeling dropping the tank as trying to sythen it with a hose was just making me high lol because i couldnt do it so i got a mobile mechanic and he pumped it out for £65 and got it up and running again, which sounded alot easier than anytrhing else
i triedwith a hoase butim guessing it had one of those valve things that stops you syphoning it as all i was getting was fumes and just made me light headed inthe end lol and i really couldn be bothered to work on me van for£65 its easier to pay someone than to drop the tank etc
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
