RS 500 suspension set up help needed
Old Mar 20, 2007 | 12:11 AM
NMS Badboy^NUTTER^'s Avatar
NMS Badboy^NUTTER^
Default RS 500 suspension set up help needed
What should i be setting the toe and camber to, front and rear on an RS500 for fast road and track use?
And same again for straight lining?
Old Mar 20, 2007 | 08:53 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
It is difficult to say, as people prefer different settings - how do you like to drive thecar / how do you like it to handle?
1. Quick turn in with nervous straight line stability (toe-out).
2. Slow turn in with straight line stability (toe-in).
3. Throw the car into the corners (high speed cornering) and relying on lots of front end grip (lots of camber).
4. Steer the car on the throttle around the corners (slow speed cornering) (not too much camber).
Different people prefer different handling traits.... .
Mine is set up for slow-turn in, but lots of stability, as I like to throw the car into the corners and lean on the grip (4x4 though....), so toe-in and LOTS of negative camber .
Old Mar 20, 2007 | 09:11 AM
Dingy's Avatar
Dingy
Nutter, make sure its all adjustable and we can try a few settings
Got some measuring devices now LOL...
RsS2daz
Aug 14, 2015 05:26 AM
dal3door
Aug 13, 2015 06:55 AM
col93saphcos
Aug 7, 2015 03:21 PM
Old ford
Jul 31, 2015 06:50 AM
