What size boost gauge is this please?
You found a tape measure then. I thuoght you wanted us to guess from the pic
I'd go for 60mm: which is the pod size. 58mm across the back so that it fits into the pod: 66mm across the front so that it doesn't fall through the pod.
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
