how do you drain a gearbox and diff in situ
Old Mar 19, 2007 | 05:48 PM
cossie2be's Avatar
cossie2be
Default how do you drain a gearbox and diff in situ
On a 2wd cossie.
Want to completley change oil on both
Old Mar 19, 2007 | 05:51 PM
foreigneRS's Avatar
foreigneRS
Testing the future
gearbox has drain plug diff does not
i uesd a vacuum pump via a big glass jar to empty my diff - and then dropped it all over myself and the floor. that stuff stinks like shit
Old Mar 19, 2007 | 05:54 PM
cossie2be's Avatar
cossie2be
Thought the box was filled from half way up, is there another drainage point
lawnsy's Avatar
lawnsy
i just losen the diff bolts off slightly then prise the cover back a couple of mill
Old Mar 19, 2007 | 07:10 PM
Graham S1's Avatar
Graham S1
why is it Ford almost never put drain plugs on g/box's
The rare exception being the 4x4 trans box.
Doing a Granada autobox was a right pain in the arse, and very messy, until I found the cheats way of doing it.
Old Mar 19, 2007 | 09:01 PM
foreigneRS's Avatar
foreigneRS
Testing the future
yes and yes
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
