my mt75 gearbox sounds like a bearing after change the oil
Mar 19, 2007 | 03:48 PM
hi
Does it change the sound of the gearbox of have standart oil or 75-90 sintetic oil ?
Now I go synthetically and now it sounds as some gearbox of motorsport.
Mar 19, 2007 | 04:22 PM
Did you put enough in?
I use the same rating Mobil oil in my gearbox and its silent apart from 2nd and 3rd as they are straight cut
Mar 19, 2007 | 05:24 PM
Mar 19, 2007 | 05:40 PM
Quote:
Originally Posted by coswol
yes i put aprox 1,5 l.
in what car m8 hope its not a cozzy as they take more
Mar 19, 2007 | 06:40 PM
Mar 19, 2007 | 07:11 PM
Workshop manual says 1.2L for the gearbox (or 0-5mm below oil level check plug)
Transfer box 0.5L (or 18mm below oil level check plug)
The std 4x4 gearbox is best off with the recommended Ford oil. I only run different as that's what my gearbox builder advised (on a Quaife gearset).
Mar 22, 2007 | 12:45 PM
yes aprox 1,2l of 75-90 penzzoil and it makes a big noise like a bearing....
Mar 22, 2007 | 03:33 PM
You did the transfer box aswell?
Mar 22, 2007 | 04:16 PM
the noise on my gearbox usually changes every couple of months.........it starts to go crack...smash...grind....whine....and then crunch........
Mar 22, 2007 | 04:17 PM
forgot to say......i use ford mt75 oil
Mar 22, 2007 | 04:24 PM
Quote:
costly
Mar 22, 2007 | 05:47 PM
Quote:
at the transfer i have put 0,5l of the ford liquid
Mar 22, 2007 | 05:50 PM
how are you getting on with the box, i have a pd box now for noddy but not got round to fitting it yet
Mar 22, 2007 | 05:55 PM
Loving it mate sounds the bollocks
Mind you i've not used it in anger yet
Mar 22, 2007 | 06:12 PM
you taking it on track anytime soon?
Mar 22, 2007 | 06:14 PM
Still a track virgin
hope to change that this year
Mar 22, 2007 | 07:36 PM
thats the spirit
Mar 26, 2007 | 02:18 PM
what about of my question?
Mar 29, 2007 | 12:48 PM
It only sounds whining when off the gas and It also vibrates when acelerating and turning right.
Mar 30, 2007 | 04:57 PM
Apr 5, 2007 | 11:08 AM
Apr 5, 2007 | 12:23 PM
Resident Wrestling Legend
you need to use the specific mt75 oil mate, that'll take ths ound away
Apr 5, 2007 | 02:01 PM
Quote:
i will try
Apr 6, 2007 | 11:26 AM
and go and find a ford guy who knows what the original oil is, not the newer stuff that ford says will do the trick (the same trick they used to flog all their 10w30 oil for every engine nowadays)
Apr 19, 2007 | 10:39 AM
well well well well
i come to put original ford e90 mt75 oil but the sounds is here.
i know that every cars round here (spain) with castrol 75/90 and they dont make noise.........
Apr 19, 2007 | 11:56 AM
are you sure it's not just a coincidence an mt75 can break at any time!
Apr 19, 2007 | 12:39 PM
mt75
looks like u need a new box
malkiemac3579
Jul 14, 2017 12:10 PM
YODI
Aug 30, 2015 01:12 PM
cameron2
Aug 25, 2015 07:18 AM
ekjim
Aug 17, 2015 08:57 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
