my zetec turbo fiesta
original thread
http://www.fiestaturbo.com/forums/my...eady-vt120609/
almost ready to go now.
heres a few pics
new spal fans
the blue hose is only a temp hose. i had to buy a few and it was trial error to get it to fit. but now i have the correct size ill order a bogey green 1
this will be cleared out.
6 months of storage and a tiny garage means my boots full i cr@p
almost ready for summer. i have to sort out a slight oil leak from the sump plug and then its (hopefully) MOT time
phoned up grove garage today about a final tweek and they can do it while i wait so thats alot easier then having to drop the car off
roll on summer
heres a few pics
new spal fans
roll on summer
Originally Posted by T4KAF
luv that,wot sort power u running m8 and wots the spec!!!!!
Focus RS Mahle forged pistons running 7.45:1 compression ratio
Focus RS rods
ARP big end bolts
Ahmed "secret spec" injectors
Ahmed Bayjoo live map
Hybrid T3 Turbo (360 degree thrust bearing, 55 trim compressor wheel, 0.63 ar exhaust housing, air cooled)
Thermotec lagged manifold
RAMAIR maxiflow cosworth induction kit
Electronic Variable boost 10-20psi
2.5 Bar MAP sensor
Uprated Escort Cosworth fuel pump
Cosworth 4x4 fuel pressure regulator
one-off custom 3 bore mongoose stainless exhaust
Pace water radiator.
GRS utralarge SINGLE PASS evo 3 intercooler
Samco boost hoses
Bailey oil seperator
Mocal oil catch tank
Spec-r swirl pot
its about 278/280bhp
Billy_RS
16
Oct 11, 2025 09:41 PM
