management 2.0zvh
Old Mar 16, 2007 | 07:13 AM
Gregor's Avatar
Gregor
Default management 2.0zvh
Hi all..
Finally decided to go efi on my 2 liter zvh turbo
Started to collect the stuf needed,,,
Only have to decide if to go ofab or cosworth..
What's best and easier to fit.
Has to run about 1.3-1.5 bar of boost..
what cosworth ecu's can i use?
Is a cos ecu with stage 1 also useable for my zvh or do i need a custom map?
And what about ofab..... get a costum chip or something else
Finally... about injectors... the blue escos can cope with 280 bhp or so..
Should i get them or go for some greens instead?
thanks all
cheers,
Gregor
Old Mar 16, 2007 | 09:26 AM
crazycage's Avatar
crazycage
Default Re: management 2.0zvh
Originally Posted by Gregor
Hi all..
thanks all
cheers,
Gregor
cosworth works out to expensive for 20 year old kit, around Ł1500, id get gotech brand new fitted and mapped Ł1000 from jamsport
Old Mar 16, 2007 | 01:14 PM
timturbo's Avatar
timturbo
ive bin thinkin gotech aswell 1500 for cosworth really is lot money
Old Mar 16, 2007 | 02:13 PM
Gregor's Avatar
Gregor
Hi all..
thanks all
cheers,
Gregor
1500 is a lot of money indeed, but i don't get where you get that from?
If it comes out as you say ofcourse i'll go for an aftermarket management but i don't see cos management coming out as expensive as you say?
And i'm not from UK so fitted and mapped wil be a bit of a problem
Old Mar 16, 2007 | 05:00 PM
grsford's Avatar
grsford
try oddkiddcreations.co.uk for a good idea of what you need for cosworth managment
Old Mar 16, 2007 | 05:54 PM
Mixja's Avatar
Mixja
420
ive gone cossie, cant see how its Ł1500 tho!! paid Ł250 for ecu and Ł35 for the wiring loom!!! everything else, you would have to buy anyway, whatever management u were using ie injectors, sensors, pullies, triggers etc...
Old Mar 16, 2007 | 06:12 PM
RST Ski's Avatar
RST Ski
ive got efi already, if i go cossie can i use my efi inlet and 1.8 cvh crank pulley for the trigger? and all i need is cossie ecu and loom?
Old Mar 16, 2007 | 06:17 PM
Mixja's Avatar
Mixja
420
need to have wasted spark driver installed into ecu to run fiesta coilpack, in which case youll need a cam sensor or u have to use a hybrid dizzy affair, cvh shaft mated to a cossie dizzy...
Old Mar 16, 2007 | 06:28 PM
RST Ski's Avatar
RST Ski
do you mean to fit a wasted spark driver into the cossie ecu if i wana keep my fiesta coil pack?
Old Mar 16, 2007 | 06:32 PM
Mixja's Avatar
Mixja
420
Old Mar 17, 2007 | 05:16 PM
Gregor's Avatar
Gregor
My thought exactly..
Already got the injectors ( blue cos ) efi flywheel, inlet manifold , fuelrail and harness. and most sensors....
just an ecu and wiring and a chip so i can run on the fiesta coil....
But a aftermarket fully mappable would be the greatest but comes with a pricetagg...
Old Mar 17, 2007 | 05:40 PM
Mixja's Avatar
Mixja
420
level 8 cossie is 3d mappable i believe... sure ill be corrected if im wrong but i was told that, thats why i went with that rather than level 6... level 8 will also run the lambda sensor which level 6 doesnt....
mk3ste
Oct 17, 2021 10:09 AM
tankybaby66
Feb 6, 2016 02:24 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
griffo69
Oct 4, 2015 11:58 AM
deathrider666
Sep 28, 2015 06:12 PM
