Charge Cooler vs Intercooler
Old Mar 15, 2007 | 06:45 PM
BlueFiesta85's Avatar
BlueFiesta85
Default Charge Cooler vs Intercooler
i have currently got a pace charge cooler setup, would it be a good idea to swap for a pro alloy intercooler setup?
can someone explain the differences between the two of the products and which one is best to use and explain why?
Thanks in advance
Old Mar 15, 2007 | 07:14 PM
addiction's Avatar
addiction
charge coolers are ok for short burst's, but with prolonged hard driving the water which keeps the boost cool heats up quickly. it then takes a fair amount of time to cool down again.meaning the act's will then be quite high!
no such problems with a good front mount like a GRS
Old Mar 16, 2007 | 07:15 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
As above, Chargecooler will be more resistant to heat-soak, so great for 1/4 mile sprints etc. Also, if you aren't running lots of boost (under 18psi).
I would go Air-to-Air everytime though. Try GRS, that's what's working for me at 30psi and well over 300bhp.
Old Mar 16, 2007 | 08:31 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
I've run a chargecooler for nine years and never had an issue, and my car is a summer only car being stored for the winter. Car pulls like a train all the time, even after and on a run.
If they were as shit as most on here seem to think ('cos most heard it on the internet so it must be true ) and no it's not a dig any anyone before all that shit starts either Pace would have gone bust years ago judging by the slagging everything they seem to make gets on here.
Old Mar 16, 2007 | 09:13 PM
PaulT's Avatar
PaulT
Go to agree with this i have a chargecooler and do not have any probs with it, have done trackdays and sprints. Its what you are happy with.
PaulT
Old Mar 16, 2007 | 10:42 PM
lewis_lisa's Avatar
lewis_lisa
PaulT
agreed
my car is only ran in summer with pace chargecooler and is shit hot
Old Mar 17, 2007 | 12:41 AM
Christian and Beccy
#1 in Spelling Club
Well, I had a Pace Chargecooler around the time I had 180bhp. It was not great, so I modified it. I added a second radiator which was a high efficiency motorbike radiator and I piped it all to the boot, where I had a second tank that held about 10 litres (the standard Pace system is around 3 litres from memory), so mine held LOTS more fluid. It still wasn't good at the boost I was running.
Upon removing it and fitting a GRS Intercooler, the difference was like night and day.
Old Mar 17, 2007 | 01:34 AM
T28 RST's Avatar
T28 RST
Ok then
I 100% agree with what Christian says on this
I had a Pace chargecooler, i thought coz it cost Ł530 it must be good, WRONG
I got another Pace radiator fitted to it, so it had 2 water radiators the same size, did it help
75 deg ACT's
You can see the second radidtor in this pic, one top and bottom
I took it off and sold it then got a custom made intercooler made, it was the best move i ever made.
Pictured here
Never seen ACT's above 30 deg with the new cooler.
Its not a case of me using high boost coz its not been above 16.4 psi
Old Mar 17, 2007 | 08:57 AM
Oranoco's Avatar
Oranoco
Bets thing I did on my Fiesta was bin the chargecooler, I've stuck a small Escort RST Pace intercooler on as a temp fix and the car seems a lot stronger on boost than with the chargecooler and the ACT's so far seem no different. We now have to Pace charge coolers in the loft as my brother never even bothered fitting his in the end and fitted a GRS instead
Fudgey
21
Sep 30, 2015 06:19 PM
