ive read alot that to get better spec out of my 1.8 silver top zetec all i ned to get is the cams and throttle bodies off a 2.0 130spec mondeo. wot i want to know is, when you mention the throttle bodies...what am i getting?? the whole efi unit as well as te inlet manifold etc then just bolt it straight onto mine and plug all the leads and hoses in etc and itl go?? or is it...as i suspect a long drawn out job? thnx
