S1Engine with PiperT2cam,Burton S2L/B Flywheel,Turbo UPDATED
Hi selling off some stuff that i wont be useing here's a list of the parts and some pics.
2wd Cosworth front 4pot calipes with BNIB Tarox Combi 283mm discs and pads.Disc's and pads retail at £250.
Calipers have had the machine work required to allow you to bolt them straight on as link below S2 section front brake page,
also been sparyed painted in black heat temp paint 3 thick coats.....Selling for SOLD
http://www.rsbible.co.uk/
S1 engine with 104000 miles on the clock Had a top engine rebuild with Piper 285T2 cam kit+Vernier,
Nordic raceing S2 stg 1 clutch with S2 flywheel built by local car tuner Ricky Gauld(Huntly) just 8127miles ago,
maintained by AVA(Glasgow)comes with graph from AVA 152.4 bhp @ the wheels,
Platinum cossie plugs done 1500miles. Run on ford synthetic oil+slick 50.
Comes with just over £1700 of reciptes for parts/labour for work done on the engine in the last 8127 miles,....Selling for SOLD
S1 T3 Turbo made decent power on my car minimal play in shaft littel smoke holds good boost.....£90
RS Turbo Exh manifold,....£15
4 Spoke RS streering wheel think it's been painted in the past
(looks very shiney compared to standerd) slight marking were the leather meets at the bottom of the s/wheel,
no other rips or marks on the leather,....SOLD
Burton lightend/balanced and doweld CVH S2 flywheel never been on car.....SOLD
Large Chargecooler rad never got round to useing it so it's new dimensions are 625mmx90mmx22mm.....SOLD
S1 Dizzy in perfect working order no tyraps holding the plug on....£SOLD
A few other bits to be added later.
Pics
2wd Cosworth brake set-up SOLD
S1 Engine SOLD
Paperwork for engine SOLD
T3 Turbo+manifold
4 Spoke RS steering wheel SOLD
Burton L/B CVH S2 Flywheel 220mmSOLD
Large Chargecooler Rad SOLD
S1 Dizzy SOLD
Many Thanks
Martin
Pics
S1 Engine SOLD
T3 Turbo+manifold
S1 Dizzy SOLD
Many Thanks
Martin
Just to add, the item I bought arrived very well packaged and just as described
Thank you very much
But unfortunately I'm a total tit as I need a wheel with a horn push
never mind, sure I'll be able to swap with someone for something one day
Thank you very much
Lightend/Balanced Burton S2 Flywheel now on ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.d...3668&rd=1&rd=1
Matt Baxter
Sep 16, 2015 08:30 PM
