Bleeding brakes, with new lines???
Old Mar 8, 2007 | 10:15 PM
Spiky's Avatar
Spiky
Default Bleeding brakes, with new lines???
i've now fitted totally new brake lines, and will need to bleed them
but is there a special way of getting fluid in??? as remember there would be no fluid at all in the system at all???
Old Mar 8, 2007 | 10:28 PM
SS1's Avatar
SS1
yes pour it in the header tank ..... sorry
i know a girl whos engine oil light came on ...
and guess where she put the oil in
yes she filled the brake fluid header tank to the brim with engine oil ..
some mothers do have em
Old Mar 8, 2007 | 11:05 PM
NUTS RuS's Avatar
NUTS RuS
leave the nipples open for a bit, whilst filling, takes the back pressure off the master cylinder seal and wont damage it.
Not a fan of pressure bleeding kits when doing that tho
Old Mar 8, 2007 | 11:39 PM
The Youth.'s Avatar
The Youth.
start bleeding the system from the furthest point from the master cylinder
steve
Old Mar 8, 2007 | 11:51 PM
SS1's Avatar
SS1
the youth
as aps have 2 bleed nipples
the calipers each sides got one
is there a special way to do it
sorry if its a question just pondering
mine are ..
Front brakes:
AP Racing 4-Pot Calipers with 330mm grooved AP discs
(40 vane race version not the cheaper road version) (New this year)
Ferrodo Ds2500 friction material. (New this year)
Rear brakes:
305mm vented disk conversion from Mike R. (New this year)
mine are a bit spongy at the moment but all garages booked up to have a look
Old Mar 9, 2007 | 08:29 PM
Spiky's Avatar
Spiky
ok, so just leave the nipples open, poor in and wait???
cheers guys
Old Mar 9, 2007 | 08:35 PM
Spiky's Avatar
Spiky
just re read that
Old Mar 9, 2007 | 08:36 PM
Paulo P's Avatar
Paulo P
Originally Posted by avid-fan
the youth
mine are ..
Front brakes:
Rear brakes:
I know on Evo's with Brembos you do the outside nipple first on each caliper and then the inside one.
The procedure for an evo is nearside rear outside, nearside rear inside, offside front outside, offside front inside, offside rear outside, offside rear inside, nearside front outside, nearside front inside That's what we did the other week and the calipers had been off the car 3 weeks.
Old Mar 9, 2007 | 08:55 PM
david's Avatar
david
cheers guys
Yes still it starts dripping through then bleed as normal
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
