PART NUMBER FOR GROUP A CAM BELT??????
Incidentaly Gates have never heard of the term 'Group A' - as far as they are concerned this is just the standard belt they manufacture for a Cossie.
(It also fits Citroen Diesels and a Peugeot from memory)
PassionFords Creator
We have had the Cosworth Group A argument on here far far too many times, and in most cases sellers are missleading people (Intentionally or otherwise before people say its me digging at other traders) by selling them standard parts labelled as something better, or, in group a cases, something "Different"**.
** Group A, for the road, is NOT usually something better.
the gates cam belt which some people refer to as a group a is a little bit wider than the standard ford item iirc and is listed as an extended service belt for the pug/citreon diesel engines.
didn't want to start a debate on the term group a just wanted to see if someone could confirm the gates part number as this is what I want to purchase
Had the number given to you NOT been wrong, i dont think anyone else would have said anything and you would have had your answer. Job done.
Would you prefer to be left with the WRONG information so everyone who reads the topic is missinformed?
As A famous engine designer once said...
"Better to be un-informed than Ill-informed."
Just checked the part number with Tracy at Cosworth who agrees with me but, as a double check has asked a fella in the spares department who actually gave the items to teh fitters back in teh day when these were new and were being put into the cars. He says it has always been teh same belt fitted and sold at Cosworth and they have never sold anything else. The Part number in question is YBO200 and has been for over 21years. It is even numbered as an old number to back this up...
For example...
The Belt Guide washer is a YB0198 and the belt pulley is a YB0197. Proving these numbers were designated right back when the engine was first designed at Cosworth around 1985.
My thoughts on this are simple... if Cosworth thought that was good enough for a cambelt, why use anything else?
The Gates 5248XS is allegedly exactly the same belt and ive fitted them for years and years.
For example...
Originally Posted by Stu @ M Developments
Just checked the part number with Tracy at Cosworth who agrees with me but, as a double check has asked a fella in the spares department who actually gave the items to the fitters back in the day when these were new and were being put into the cars. He says it has always been the same belt fitted and sold at Cosworth and they have never sold anything else. The Part number in question is YBO200 and has been for over 21years. It is even numbered as an old number to back this up...
For example...
For example...
thanks for checking
Originally Posted by Doug Stirling
This is the belt supplied by Cosworth:
Someones on teh fiddle... ROFLOL
You gotta love good old England for things like this. Cosworth have catagorically stated to me they have not, EVER sold any belt other than the YB0200. Yet they personally sold Doug one without a Cosworth part number on it.
Someones on the fiddle... ROFLOL
Originally Posted by TF Rallyesport
group A cars use the high temperature one,as ian has pointed out.
That one was purchased about two years ago, check with Julie or Lisa to confirm what they are supplying this week
I dont like to disagree, but HTD means High Torque Drive....when applied to a synchronous belt, AFAIK the mountune belt has a different cord material, one used for higher engine bay tempertures experienced on the Grp'a' and wrc cars with ALS etc....
I have had some dealings with both the standard and mountune belts, even to the point of analysis with gates when we had 2 failures on rallies using the standard belts. We now dont use anything other than the mountune item.
That said under normal road even mild track conditions, the cosworth belt is quite adequate....in my opinion...
Ian, talking of World cars, when are we finishing the mapping on yours? Its been a while mate, you must be snowed under with Ł20 notes by now...
Originally Posted by GARETH T
and when are you doing a rally down south, so i can pop along for a butchers
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
rog
Sep 4, 2015 07:24 AM
Any decent rally action in Wales at all Gareth
