Retro fititng a/c to cars..
Mar 7, 2007 | 12:29 PM
can this be done and who can do it?
is it expensive to do?
Mar 7, 2007 | 02:28 PM
Of course it can be done, but all depends on what car for cost etc..
Mar 7, 2007 | 03:20 PM
Mar 7, 2007 | 03:24 PM
i think you can get aftermarket aircon kits. try looking at some US websites
Mar 7, 2007 | 03:33 PM
Get all the parts of a saff that was fitted with Air Con. Then fit it your self etc. Though not sure what you do with the old ac on gassing them
Mar 7, 2007 | 03:45 PM
you carnt fit aircon for a sierra to a non aorcon model unless you change the top half of the centre bulkhead
as the bulkheads are different
Mar 7, 2007 | 04:53 PM
And unless you get the right block, there'll be nowhere for the AC pump to go...
Mar 7, 2007 | 06:23 PM
Resident Wrestling Legend
you can make the pump fit, it's getting the parts that are cossie specific that is going to be the problem
don't forget you'll need the pipe work and LOADS of loom to get it all working as it should do with the recycle and all that
Mar 7, 2007 | 06:38 PM
ForeigneRS off here fitted aircon on a 1972 mk1 escort
Mar 7, 2007 | 06:42 PM
he works for an ac company so he may have a slight advantage in requesitioning bits and bobs
Mar 11, 2007 | 03:54 PM
steerfromdarear
28
Jan 29, 2016 06:14 PM
pabloXR
Sep 21, 2015 12:42 PM
23
Sep 12, 2015 12:56 PM
Adam Graham
Sep 6, 2015 06:04 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
