FAO Pet: "Quote the text that you gently..." featu
Sep 11, 2004 | 08:33 PM
Pet,
it doesn't work with mozilla (v 1.7.1), works fine in IE. Is there something "special" about the code you are using for this to work ?
Could you have a look if/when you get a chance ?
Merci beaucoup.
Sep 11, 2004 | 09:14 PM
Just tested it, and can confirm it also doesn't work with Opera (v 7.50).
Sep 11, 2004 | 11:06 PM
That makes two of us then
Sep 13, 2004 | 07:58 PM
for pet.
Sep 13, 2004 | 08:20 PM
mmmmh.
yes i see what the problem can be.
i'll check and try and make it compatible in Mozilla
cheers for the feedback; merci beaucoup
Sep 13, 2004 | 08:29 PM
Sep 13, 2004 | 08:31 PM
Sep 13, 2004 | 08:34 PM
ok i made a change in the code, can Mozilla users test it now ?
Sep 13, 2004 | 08:53 PM
Quote:
Originally Posted by Stu @ M Developments
reddit.
(oh, and before you ask - so is mrs frog
Pet, change made no difference I am afraid
Sep 13, 2004 | 08:54 PM
ok, let me check another thing
thanks for your patience
mjonathan24
Oct 29, 2015 10:39 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
3doorcozmess
Sep 20, 2015 06:15 PM
Tim Wharton
Aug 28, 2015 08:26 PM
smiley
Aug 16, 2015 06:36 PM
