People with 400+ bhp (cosworth) 4x4 inlet fitted
Old Mar 6, 2007 | 06:12 PM
radiant red's Avatar
radiant red
Default People with 400+ bhp (cosworth) 4x4 inlet fitted
What inlet manifolds are ppl using?
Im purchasing a 4x4 cover from north york tom as my crappy Swedish one has split!!
Just wondering if i need a spacer to allow sufficiant air flow?
ta
Old Mar 6, 2007 | 06:15 PM
Billabong's Avatar
Billabong
Was it a 'Swedish' one or a cheap copy?
I'm on std EsCos one, but 'O' ringed for a better/more reliable seal.
Old Mar 6, 2007 | 06:16 PM
abdr500's Avatar
abdr500
escort cosworth small turbo inlet good for 500 bhp
Old Mar 6, 2007 | 06:17 PM
radiant red
defo cheap pal,came witht the car apparently the last owner suffered some probs with it
i have a full cometic gasket set
Old Mar 6, 2007 | 06:19 PM
Billabong's Avatar
Billabong
Just noticed your sig - you should be fine with what you're getting. If the spacer makes a difference at your power level, you'd really need a remap too....
Old Mar 6, 2007 | 06:27 PM
radiant red
oh i see,well the car should be more like 450 with the full 34 psi which i WILL run on the drag strip etc.The day of the RR it was hitting around 26 psi.I am aware it will be benaficial lower down witht the standard plenum just need to know if ill be ok running this kinda boost level through a t38.
Old Mar 6, 2007 | 06:32 PM
NEIL A's Avatar
NEIL A
Think the 4x4 cover is good for around 450 , small turbo 500 and rs500 cover 550+.
Old Mar 6, 2007 | 06:33 PM
rapidcossie's Avatar
rapidcossie
its not really the plenum thats the restriction, its the elbow.
As abr500 says the eecv small turbo escort is a cracking inlet.
Mines made 453 ATW using one.
Old Mar 6, 2007 | 06:34 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
i'm on standard 4x4....
Rhys's Avatar
Rhys
For 400 i used std inlet!
Old Mar 6, 2007 | 06:35 PM
radiant red
So the elbow on the 4x4 cover is restrictive then,sounds like its up to the job so ill bolt it up and see how it goes.
Old Mar 6, 2007 | 06:54 PM
Butch.'s Avatar
Butch.
pete send me your 4x4 inlet cover and i'll get this done to stop the restriction on the elbow
Old Mar 6, 2007 | 07:39 PM
pig's Avatar
pig
mines a small turbo escort cos item on mine
Old Mar 6, 2007 | 07:56 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
I have a Swedish replica inlet plenum, made to replace an ally one that split a couple of times along the welds (after ballooning up anytime it saw decent boost)
Not had a problem with mine, Doug Stirling also uses the same one on his 568bhp car.
Si
Old Mar 6, 2007 | 07:59 PM
cos47's Avatar
cos47
Si
Top quality these are
Old Mar 6, 2007 | 08:17 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
pics of your split please!
Old Mar 6, 2007 | 08:34 PM
col cos1's Avatar
col cos1
i was meant to be getting 1 of these sweedish style ones but it fell through....il get one later in year,think my standard 2wd one is maxed now aswell
Old Mar 7, 2007 | 05:04 PM
YBP's Avatar
YBP
Small turbo escort. Slightly ported just to take the rough off it. 480bhp No spacer of course.
Old Mar 7, 2007 | 06:57 PM
radiant red
cheers butch
gonna pick one up tom and ill get the welding done using the picture you posted
Hey im down your way tomorrow,calling at turbo techinics
Old Mar 7, 2007 | 06:59 PM
radiant red
will do mate,the top weld has split all the way along about 6 inches long
Old Mar 7, 2007 | 07:13 PM
Butch.'s Avatar
Butch.
i'll be round northampton somewhere, what u doin getting your wastegate arm fixed
Old Mar 7, 2007 | 07:22 PM
radiant red
yeah fukin things nearly twisted off
from there im up to scarborough for the 4x4 plenum unless someones got one down there???
oh and a boost hose
Old Mar 7, 2007 | 08:54 PM
Escos Jam's Avatar
Escos Jam
I use an rs500 inlet on mine mate
Old Mar 7, 2007 | 10:56 PM
radiant red
Originally Posted by MAD YUM
This is mine
yeah thats ok i guess
Old Mar 7, 2007 | 11:19 PM
aduz's Avatar
aduz
This is mine
show off
Old Mar 8, 2007 | 08:07 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
That's the problem with some of the copies, they're not fit for purpose . I have seen LOADS of these do the same thing. Not ONE of our proper Swedish ones have failed in any way, shape or form .
Now you know why the copies are "cheap" .
Old Mar 8, 2007 | 08:13 AM
AlexD's Avatar
AlexD
Post Miester !
Might get that mod done on mine then..
Old Mar 8, 2007 | 08:19 AM
Dingy's Avatar
Dingy
Mine is an NMS custom one...
Run's over 700bhp on karl's 3door
Old Mar 8, 2007 | 08:27 AM
....Dingy but Karls isnt a PROVEN 700bhp
Old Mar 8, 2007 | 08:28 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
is that the same 700 bhp that piloted his 3 door to 220 mph
Old Mar 8, 2007 | 08:38 AM
Dingy's Avatar
Dingy
Made over 550 at the wheels mate does that count.....
220mph on the m42 Mint
oops soz, brunters only lads
Old Mar 8, 2007 | 08:45 AM
CossieRich's Avatar
CossieRich
rofl
didnt it have a standard coil on it. 220mph on the m42.
Old Mar 8, 2007 | 08:47 AM
R4N SS's Avatar
R4N SS
mine is on std inlet
Old Mar 8, 2007 | 08:58 AM
Dingy's Avatar
Dingy
rofl
Nope a GRP A item but what has that got to do with it
Dingy's Avatar
Dingy
Mine makes just under 500bhp at 26psi......to 7000rpm...
Old Mar 8, 2007 | 08:59 AM
...even i have to Barry Chuckle at 220mph
Old Mar 8, 2007 | 09:06 AM
CossieRich's Avatar
CossieRich
rofl
A Grp A item with 700 bhp and 220 mph? You think its man enough? Dont think so Dingy
Old Mar 8, 2007 | 09:08 AM
bud-weis's Avatar
bud-weis
Football Cwazy
rofl
it is a weapon mate with his current gearing he reaches the limiter (188mph) by the time mine is just about 145mph ish..... measured on the same stretch of road (which isn't that long!)
it's only because he has no interest in competition that we haven't seen more of it
i wonder if he'll lend it to me for the Pf thrash
Old Mar 8, 2007 | 09:11 AM
CossieRich's Avatar
CossieRich
rofl
Not doubting it is a weapon mate, but 220 and no its nothing to do with being MAD, its just i dont beleive he did it thats all
IF the thrash ever gets going, keep on at Karl night and day to turn up
