Whos still got what to do before the Nurburgring Trip then??
Following on from ^NUTTER^s thread about him only just getting his engine.....who's got what to do to their cars????
Heres my list.....
Pickup new rear beam assembly inc diff from Milton Keynes & fit,
Pickup adjustable shocks & wheels from Somerset & fit
Fit new big ends & oil pump,
Oil & filter change,
Refit exhaust manifold
Build up turbo with cossie rear exhaust housing & fit
Fabricate 3" downpipe & fit
Refit exhaust
Finish off fitting boost controller
Fit oil cooler
Fit new radiator & slimline fans
Then if parts arrive from Belgium I'll fit my 3BAR MAP sensor, 355 injectors & new chip!!!!
Then if I've time I might do a bit of sleeping & drinking inbetween all this and may even give it a wash & polish if its lucky!!!
Oh yeah & tax the bugger!!! LOL!
Heres my list.....
Refit exhaust
Fit oil cooler
Originally Posted by Ryan
what car u takin this time lee?
Taking a spare headlight & indicator incase I meet with the armco again!!!
Got to get the car started and then set up which fingers crossed will be this week.
Fit new suspension which is in my garage as has been the last 5mths
Buy new poly bushes and fit.
Oh and sort out recovery incase it breaks
Originally Posted by Chip-3Door
Nothing at all, going as passenger (probably for the best, lol)
Get some milage on the gearbox
Get car checked over and set up
Fit coilovers
Get the 4x4 ready
Originally Posted by Jim Galbally
fill up with fuel
if i get some cash, i MIGHT swap the tyres for Eagle F1s, but thats the MOST i'll do to the car
From: Dewsbury, The parts were they don't abduct their own children!
Pick the car up on Saturday,
Only a passenger side lower arm and the spare wheel cage to fit
Ready to go apart from that!!
oh and i better top up some oil as when stu checked it 2 weeks ago he told me it was just below the min level
owning a bmw,,,,,, you just dont get a reason to open the bonnet,,,, infact im starting to find it a chore to stick the keys in the ignition
Originally Posted by Stu @ M Developments
Nothing dramatic.
Poly busy the front arms. Fit 2 rear tyres.
Me personally - everything as usual, although this time round I won't be running my car in on the drive over there!!!
Si
Get two snapped studs spark eroded out of the head...
Get 1 snapped stud out of the turbo
Build up the motor with new grp A gasket etc
Ultrasonically clean and flow test the injectors
Fit exhaust system
fit new front discs and pads
Drain fuel tank of stale fuel
Get running and set up fuelling etc
Mot and Tax
Valet
Etc,etc,etc(Must be loads more i missed
Car has been laid up for 14 months so i`m sure there will be more minor bits...
This is the 4x4 by the way,the escos is sorted....
Fit exhaust system
Mot and Tax
Valet
)Car has been laid up for 14 months so i`m sure there will be more minor bits...
How the patient currently looks as of tonight....
Oh yeh I'd forgotten a couple of jobs.....fit different clutch master & clutch slave seal kit & bleed system, fit new samcos, wrap downpipe & helicoil two cylinder head exhaust studs!!!
Lambchop.....our backup plans...we have a few dont worry...
1.) Walk
2.) What car did you say you've got again...
3.) Jump in with someone else
4.) Get a taxi
5.) I've got another Quadra we could go in
6.) Go in the trusty TDI Bora!!!
1.) Walk
4.) Get a taxi
I am not technically on the same trip as you guys - not going till April 28.
But......
Engine out of car.
Block done
Head now completely stripped including valve guides.
So not much to do then!
But on the up side, I have rewired a good deal of the car
JJ
But......
Engine out of car.
Block done
JJ
Originally Posted by phill2400
Go get cossie out of its box wash it polish the bling and go (just like any other week end)
JJ
Well i've got a weekend trip all around th country to pick up some shonky old Reno bits
To repair the car from it's last outing due to the driver (LEE)
running out of talent on a minor bend
Good job i have a big van and trailer, i dunno what my mates would do without them
Originally Posted by dingy
Is your engine done then mike ?
What power did it make ?
. All in hand to be resolved in time (I hope
1.) Walk
4.) Get a taxi
1.) Walk
4.) Get a taxi
We're NOT taking my maxo!
Another quadra? Which exactly is your main toy? Have you got another 21?
The Bora would be ok
