Cosworth 3 door amplifier
Old Mar 6, 2007 | 07:53 AM
Mark 3D's Avatar
Mark 3D
Moderator
Default Cosworth 3 door amplifier
Need a bit of help.............
Where the amp is or was in my cossie i have a plastic tray fitted there probably from a Sierra GL or something.....
anyway... I recently bought a spectrum analyser which i thought i would put there instead so I have taken the tray out and found the hole to be bigger than than the width of my analyser. The analyser is the size of a standard car stereo.
my question is firstly will the analyser fit in where the amp once was and secondly can I buy some sort of fascia plate to make this a neat job?
Thanks a lot,
Mark
Old Mar 6, 2007 | 12:01 PM
Mark 3D's Avatar
Mark 3D
Moderator
bttt
Old Mar 6, 2007 | 05:11 PM
Mark 3D's Avatar
Mark 3D
Moderator
anybody?
Old Mar 6, 2007 | 05:25 PM
nellyscossy's Avatar
nellyscossy
no you cant get a plate and no the analyser wont fit!!
if you change the bottom dash piece for a later saff one then it will but then there are issues with the bracket that fixes the dash to the tunnel in front of the centre console
Old Mar 6, 2007 | 05:29 PM
Mark 3D's Avatar
Mark 3D
Moderator
Hello m8,
oh thats a bit of a bummer!!
Thanks for helping me out with that though, i shall just have to sell the graphic on!!
Cheers,
Mark
Old Mar 6, 2007 | 06:17 PM
stickertone's Avatar
stickertone
Default how to fit spectrum
call me on 07860650755 and i'll tell you how to do it... cheers
jessie_rs
11
Jun 3, 2019 04:57 PM
COSWORLD
Aug 14, 2015 07:40 AM
Aug 14, 2015 07:29 AM
dal3door
Aug 13, 2015 06:55 AM
Old ford
Jul 31, 2015 06:50 AM
