11 minutes of CNC Porn
http://www.youtube.com/watch?v=QsmiIeAkE-o&NR
Finishing the bores with a ball nose cutter and using every axis is just showing off
Mark
Mark
some damn good programming, i work running an snk120 (also a matsuura machine)doin aerospace, we've recently been proving out new work thats been using all 5 axis to the full, feckin scary when the tool heads in and your not quite sure if itsgoin to stop!!
CUNT!
From: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
Originally Posted by boXXer
how much programming is involved in something like that? i.e, how long would it take to write the info?
Working out 4, 5 or 6 axis worth of movement is just way too complicated for anything other than a computer.
Its not often I'm really impressed with CNC stuff as I seem to spend most of the day watching them so they get boring after a while but the V8 cylinder block machining was very impressive as are a few other videos on You Tube:
Theres also one of a W16 engine:
http://www.youtube.com/watch?v=GU32Q6QXtWQ
The co-ordination of this machines is incredible, amazing to watch work:
http://www.youtube.com/watch?v=s6jtF...elated&search=
The speed this horizontal can remove metal at is also amazing:
http://www.youtube.com/watch?v=YG_A6gvOS24
Billet Crankshaft being machined:
http://www.youtube.com/watch?v=E1Fj1j8Sg1g
There is also a hybrid turning / milling centre which on there some where which is an interesting looking machine.
Originally Posted by philram
have you ever noticed that they always demo in alloy though
untill i started my apprenticeship and started turning and milling i didnt realise what u could do to a bit of metal.
and then i went and made things like an adjustable scribing block all by hand.
Originally Posted by GARETH T
Originally Posted by Frogford
Its only a five axis machine
My old one was six axis and amazing
But it was one of these
and it had 2 tables as opposed to the one in the picture
the company I worked for had 2 of the bugger a and also a 5 avis Anayak. The bed on that was about 30ft !
My little brother used to run a CNC milling machine which had a specially lengthened bed so they could make the spars for A3** airbus wings and that bed was just short of 100metres. Was fucking massive.
Originally Posted by mk1_orion_boy
Thats amazing
Is it sped up? How does it not go blunt?
Coated tungsten carbide tooling will last for ages on Aluminium and you can use crazy machining speeds.
It would be a LOT slower if it was tool steel instead of ali.
Mark
try doing that in some of the steels we use
were the only company that do the propeller hubs for dowty,like the dash 8 and we do the rotors for westlands
people outside of engineering think its cool but i guess we are too used to it
couple of pics of the stuff we do
stunning
the bores are cool... i need to get on one of these, im sick of turning now and need a new challenge
