What power do you think this rst will make
Old Mar 4, 2007 | 08:59 PM
Alps Pacino's Avatar
Alps Pacino
Default What power do you think this rst will make
This is the spec,
rebuild bottom end
standard head and cam
Standard mfi no 5th injector etc
stage2 turbo
Pace front mount
chip
exhaust and filter
Old Mar 4, 2007 | 09:00 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Std new cam/tappets?
I reckon circa 170bhp @13psi
Old Mar 4, 2007 | 09:01 PM
Paddy rst's Avatar
Paddy rst
around 185bhp.
Old Mar 4, 2007 | 09:04 PM
Eagle's Avatar
Eagle
Super Moderator
190 i recon
Old Mar 4, 2007 | 09:06 PM
...is it Heinz
Old Mar 4, 2007 | 09:11 PM
Alps Pacino
Bosch-Man
Branston only the finest
vroooom ptssssh
Original cam tappets etc
The lad recons he's got 200bhp at the mo, with chip exhaust and filter. He recons with the addition of a stg2 turbo and a pace front mount it will be 250bhp
Old Mar 4, 2007 | 09:12 PM
big_wig_074's Avatar
big_wig_074
uhuh,250bhp?????
Old Mar 4, 2007 | 09:13 PM
T28 RST's Avatar
T28 RST
Ok then
Old Mar 4, 2007 | 09:17 PM
vroooom ptssssh
It Wasnt Me!
A very good stg1 engine/setup is 180bhp
rebuild bottom end
stage2 turbo
Pace front mount
chip
exhaust and filter
Thats all really stg1 stuff & an old cam..barring the Stg2 turbo..but it's only running at around 14psi, (any more and the pace interwarmer wont be much use, they are not much better than std)
The filter will be drawing in hot air....so i'd stick by my guess of 170@fly/ 140@wheels.
Old Mar 4, 2007 | 09:29 PM
Alps Pacino
A mate of mines car with brand new ford engine forge double capacity intercooler exhaust anf filter made 204bhp but that was fast as fuck back in the day
I tried advising him on a few things but its hard telling people when your new to a site and no one knows that your pretty clued up on certiain things. My speciality is rusty old shonky fords
Alps Pacino
vroooom ptssssh
ps it running 16psi for its 200bhp
Old Mar 4, 2007 | 10:10 PM
Dicko&Vacant's Avatar
Dicko&Vacant
whos is that mark?
you scared it will do the teg in pmsl
Old Mar 4, 2007 | 10:40 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Well,It'll defo make 132bhp
na, I'd say 170/180
Old Mar 4, 2007 | 10:57 PM
plynchy's Avatar
plynchy
Probably piss on your Escos by the sounds of it...
Old Mar 4, 2007 | 11:00 PM
chummer's Avatar
chummer
185 bhp for me
Old Mar 4, 2007 | 11:36 PM
sm's Avatar
sm
should be around 180-190bhp my old s2 made 188bhp and 198lbs of torque with a filter, chip, exhaust and pace cooler running 17psi
Old Mar 4, 2007 | 11:41 PM
badboy rs's Avatar
badboy rs
ye mine had the same spec but with a grs cooler, it made 194 bhp runnin 18psi but my engine was in mint condition.
he ll only achieve 250 bhp in his dreams, some people do talk bollox
Old Mar 4, 2007 | 11:44 PM
boXXer's Avatar
boXXer
GASH!
what should a stg1 car do with exhaust and filter, and std cooler @16psi?
Old Mar 4, 2007 | 11:52 PM
vroooom ptssssh
It Wasnt Me!
boXXer, At 16psi on a standard cooler the ACT temps will be off the scale, 14PSI the cooler is on its maximum cooling limits and not many people set them to run 14psi on std cooler, at max i'd run it at 13psi, i'd guess at an exhaust (filter...wouldnt use a cone, again raises ACT temps) a chip (cant run over 10psi without one) and a -31 and 13psi - 160@fly roughly?
figures seem to be exagerated south of the Scottish border for some reason?
Old Mar 5, 2007 | 12:01 AM
Alps Pacino
Dicko&Sarah
Fuck you
plynchy
And fuck you
Old Mar 5, 2007 | 01:10 AM
TrevCannon's Avatar
TrevCannon
Defo no more than 170! engine old!!!!
Old Mar 5, 2007 | 01:14 AM
vroooom ptssssh
It Wasnt Me!
TrevCannon, It has a rebuild bottom end, but its not had a head rebuild app.
Old Mar 5, 2007 | 02:20 AM
plynchy's Avatar
plynchy
Alps Pacino
Thats a lot of fucks for a Sunday night mate
My old S1 RST (years ago) got stg 1 chipped, std filter and exhaust and had a print out for 185 BHP, went like fuck, and lost Ł100 on it when I sold it after a year, bloody nice car that.
Old Mar 5, 2007 | 04:41 AM
Charlie Chalk
Unknown.
I've got a 2wd cooler if you want Mike..?!
Old Mar 5, 2007 | 10:20 AM
boXXer's Avatar
boXXer
GASH!
so have i! Where the hell would you fit it though?
Old Mar 5, 2007 | 10:21 AM
boXXer's Avatar
boXXer
GASH!
Hiya mate. Thanks for that.
BTW, what would you call a "high" ACT temp? as i have a gauge coming off the plenum.
Old Mar 5, 2007 | 10:23 AM
Charlie Chalk
Unknown.
Make it fit and get a reversed charge carrier..
Old Mar 5, 2007 | 10:24 AM
boXXer's Avatar
boXXer
GASH!
you got me thinking now. Where would it go exactly? might start a post about it.
Old Mar 5, 2007 | 10:28 AM
Charlie Chalk
Unknown.
MJC has fitted a 4x4 cossie cooler, So I would think that a 2wd one would be pretty much the same..
Here's a link I just dug out
https://passionford.com/forum/viewto...003&highlight=
Old Mar 5, 2007 | 11:37 AM
JamboRS's Avatar
JamboRS
focus rs 1672
any more than 50 degrees is getting into high territory
Old Mar 5, 2007 | 11:51 AM
DanRSturbo's Avatar
DanRSturbo
Pace cooler's good for 190 odd horses max, to get past the 200 barrier he'll either need a chargecooler or go big front mounted really. Mine run's 18 psi on a pace chargecooler and made 190 horses, but that's due to the engine on just under 140k with no rebuild
Old Mar 5, 2007 | 02:06 PM
JimmyBoy's Avatar
JimmyBoy
What exactly is the purpose of a -31?, does it just help hold higher boost levels and avoid any possible spikes ?
Old Mar 5, 2007 | 05:11 PM
JamboRS's Avatar
JamboRS
focus rs 1672
why is everyone talking about it NOT having a front mount,it clearly states at top that its got a front mount pace,which ive heard are as good as grs and the like
with they mods,power is always dependant on condition of parts,timing,boost and a shit load of other things but could see upto 190-200@fly with 18psi or could be as low as 160@fly on around 13psi,stumbling block is always the metering head,that will decide on how much boost you can run,ive seen ones being sucked dry at 11psi
Old Mar 5, 2007 | 05:18 PM
boogaloo's Avatar
boogaloo
i reckon 180-190.louisexxx
Old Mar 5, 2007 | 05:38 PM
boXXer's Avatar
boXXer
GASH!
right, mine runs 160hp @ 13psi, so i take it thats about right? So, in theory, i should get 180 hp @ 16psi? As mine runs about 55 degrees ACT temp when on full throttle @ 16psi @ 5k.
Mike
Old Mar 5, 2007 | 05:56 PM
vroooom ptssssh
It Wasnt Me!
Good point, actually I just assumed it was the pace large capacity cooler.
Then again, look at the green shed..265@the wheels on MFI
boXXer, I'd say no, not just by turning the boost up...with a better IC/setup/bit more boost yes. 55 degree's is a bit hot already?
Old Mar 5, 2007 | 06:03 PM
JamboRS's Avatar
JamboRS
focus rs 1672
the green shed had a modified metering head just like mine and was running 2 pumps,i know mines ran out of fuel at 195@wheels,which is supposed to be quite decent for this,ive also seen my mate swhich ran out of fuel at 160@wheels and one at 120@wheels,its a hit or miss with the MH's
Billy_RS
16
Oct 11, 2025 09:41 PM
JK12
33
Apr 26, 2021 12:09 PM
Chas
Sep 21, 2015 08:57 PM
A.t.p
Aug 15, 2015 11:37 AM
dlwarrior
Aug 5, 2015 10:19 AM
