Need help with stage 3 conversion
Old Mar 4, 2007 | 05:05 PM
cossie2be's Avatar
cossie2be
Default Need help with stage 3 conversion
My engine has group a gasket and other bits, i have bought a stage 3 kit off someone on RSOC.
Consists of T34, Rs500 Cooler, Stage 3 Chip, set of Greens, 3 bar map sensor.
The T34 has a -34 and has had the preload set by turbo technics
The car only boosts to 17psi, how do i increase to 22, i can wind out the actuator and it increases but i thought you shouldnt overload it
Someone suggested rejetting amal, is this correct, if not what do i do
Old Mar 4, 2007 | 05:49 PM
Carlsworth's Avatar
Carlsworth
Former Sponsor
preload on actuator with be fine at 22,...
Old Mar 4, 2007 | 05:53 PM
big_wig_074's Avatar
big_wig_074
wind actuator,bleed valve,boost controller,loads of ways.
Old Mar 4, 2007 | 05:55 PM
Jasesapphy's Avatar
Jasesapphy
thanks, i will just wind the actuator then as it made 22psi no problem just that turbo technics were banging on about too much preload e.t.c
Old Mar 4, 2007 | 06:06 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
u wind the rod IN to make more boost.....
Old Mar 4, 2007 | 06:26 PM
Jasesapphy's Avatar
Jasesapphy
you know what i mean
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
SMILER258
Sep 28, 2015 09:04 AM
