** Track Prepared Mallard Green Escos **
Old Feb 27, 2007 | 03:40 PM
Gatecrasher's Avatar
Gatecrasher
Not welcome...
Default ** Track Prepared Mallard Green Escos **
Hello Everyone
Ok on the 23rd of December 2006 i got my first Escort Cosworth
It is a 1994 L reg Mallard Green, Large Turbo T34 model with full raven Black Leather
Pic is of the first day i got it
Ok Now the bad bits I paid £9000.00 for the car and where i was so excited about getting one it was from a friend of a friend who said it was mint blah blah blah so i took my mates word who took his mate word who said it was sweet when i went ot buy it, it was Dark and after a go round the block i was hooked and within 2 minits of that i was on the way home
once i got it home and hada good look i realised the Hocky stick that was broke was slightly more than it first seemed and needed a new one aswell as a new washer bottle as at the time of impact when the hockstik got broke it did this aswell
This was all i see the night i brought it
anyway after close inspection i see that the Stone deflector on the front bumper was split and scraped quite bad aswell and needed replacing! not to mention it had a bad oil leek that pisst all over my new drive "dont know how i never see that when i brought the car" and inside there was also a few dodgy bits going on i see straight past when buying it
Steering wheels is ok but standard is better, as is the bost gauge holder on the steering casing that is now standard, the gearknob is momo, looks shite and is a total cunt to get off, the hand break has a chrome cover on it i can only discribe as being the size of a can of redbull
The oil leek only turned out to be the seals otherwise i was told it was an engine out job for the sump gasket seals among other things to be done, whitch would have been a total nightmare and cost a fortune aswell why i was there i had a new cam belt, oil filter, oil, fuel filter ect all done fir good measure
Ok so not to many probs thought i would just sort a few things out and get it looking sweet new set of wheels ect, the power was pretty good i was happy with it felt a bit laggy but hey its a 13 year old car!
My mate has a go Slates it says its a pile of shite and Buys and M3 E46 2002 and said it will and would eat my motor any time place or day wanker! this is my best pal BTW and the guy who said it was his friends who said my car was mint GAME ON!
Not his car but just to give you an idea case you didnt know what one is
Nice Car!
I now had the duty to not be muged off and get my car to be capable of obliterating his M3 round a track and on the road! now for a start i know my car is 4WD and his is RWD so i got a head start there and he will not tune hie motor at all he belives no matter what i do to my escort his in standard form will wipe the floor with mine please bear in mind he has had a go in my car when i first brought it at best being a stage tired stage 3 that was probebly carried out 7 years +ago whitch consisted of
Dark Green injectors, 3Bar Mapsensor, K&N induction, Stainless steel Exhaust, Breather system and from the Receipts that i got an uprated Fuel pump! from what i have been told all work was carried out buy Grove garage/Ahmed Bajoo? not to sure if anyone reading this knows any diffrent please let me know as im allways intrested to know about the history of my car
BTW remember when it was snowing a few weeks back? he ditch the M3 new front bumber, wing, headlight bonnet wishbone shouldnt laugh but its nearly repaired now anyway
So getting back to the Task at hand the stage 3 was never gonna cut it so i set about specking up a faster version of my current spec!
First thing i brought was a set of Grey injectors from Kevin Sharp on here
The turbo that was on the car sounded & went really good but i knew it wasnt up to the job at hand so it was swapped for a Grp A, T34 + .63 REAR HOUSING, 247 MARAM ANTI LAG SHAFT (stamped with 247), 360 BEARING, STRENGHTENED WASTEGATE ARM, QUICK RELEASE EXHAUST HOUSING, POLISHED/MACHINED OUT RESTRICTOR FOR FULL FLOW AND NEW BEARINGS & SEALS ETC 550 MILES AGO BY FIELD MOTORSPORT
as i was changing the Turbo i remember from an article in a mag that 2WD exhaust manifolds flow better than 4X4 so i brought a new one from GGR on ebay
whitch i then realised i needed the Trowsers/elobow bit that goes inbetween the Turbo and Exhaust manifold luckly Ryan who makes the sick Cossie looms came to the rescue with one
Old Feb 27, 2007 | 04:08 PM
Gatecrasher
Not welcome...
Ok so now i knew what i needed to do with only being out in the car a handfull of time i took it to my lockup/yard and started stripping the engine down thought i could remember where everything went, that was a good few weeks ago now
Why i was there i also took the front bumper off to sort out the stone defloctr issue aswell as the cam cover, oil seperator, strutbrace and trumpet for the K&N
i sent sent the cam cover, oil seperator, strutbrace and trumpet for the K&N off to Mike rainbird to powdercoat in Candy apple Green wich mike done Blue sorry mike couldnt let you get away scott free after you having a Dig about the colour of the bits i sent
why i was there i also brought a defi 60mm Boost gauge on a piller pod a banana pod to hold 3 defi gauges, center consol that is being modded like francos but to hold 3 52mm not 60mm defi gauges
A Short shift and monte gearknob to get rid of that shite Momo one thats still on the car that i still cant get rid of
Head gasket and Head bolts
K&N Filter to fit my trumpet as mine is all old oily and bent up
Bracket for the Actuator on my turbo as the one that i got from M_K was moved to fit his XR2 so it wouldnt hit the rad/intercooler
ACT Gauge in Green to keep an eye on temps
Water injection full kit to keep things cooler
Also orderd a set of the Diamond headlights you get for the moretts i think they look the bolocks
Old Feb 27, 2007 | 04:25 PM
M.A.D.RST's Avatar
M.A.D.RST
Good post mate, keep the updates coming Its always good to see the escorts of people who post in the escort cosworth room
Im liking the candle apple green What other plans do you have?
Will it be complete/finished ready for the shows?
One thing i have to say, and i do apologise but...................with that first pic you put up and then reading underneath with you saying your mate said it was mint, now that made me laugh, especially at that price too
Old Feb 27, 2007 | 04:30 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Coming along nicely mate!
Don't worry about not seeing things when you went to see it - it's called Cossie Blindness and has caught many people out.
Keep the Morrettes and smoked indicators on though they look sweet
Old Feb 27, 2007 | 04:39 PM
KSA-Cossie's Avatar
KSA-Cossie
Mallard green escos bt model is my next car deffo.
Old Feb 27, 2007 | 05:00 PM
STUCOS's Avatar
STUCOS
Nice mota.wouldnt worry about not being mint at that price as it would break for that,nice colour,in my opinion ,
cheeRS stu
Old Feb 27, 2007 | 05:31 PM
Dan's Avatar
Dan
Nice little thread mate!
That is one cheap Escort Cosworth for 9k mate! At that price it's going to have problems, remember you only get what you pay for...
As for your so called mate, i'd smack the cunt for telling you a load of bullshit about the car and i'd put the cunt in fucking hospital for then slagging the car off, think you've been done here fella, don't sound like any kind of friend at all!
Finally, WTF were you doing buying the car in the dark!
Best of luck with it mate, sure your gonna be fine, keep the wheels too, the dish on them looks
Old Feb 27, 2007 | 05:47 PM
Gatecrasher
Not welcome...
Spose i should have expected a bit of abuse about buying the car in the dark LMAO!!
Le me tell you a bit more! the guy who owned the car befor me i know to buy and sell cars all the time and to be an ok fella! bbut not a personal friend
I was out with my pall when the guy called him and said he had just brought a cossie, i asked a few questions and said if ever he was selling it and it was give away money to let me know
3 months later and he board with it and said it all fine runs like a dream whitch it does/DID nothin wrong with it other than the hocky stick being broke where his other mate hit a kerb or whatever!
now for a normal person my car in the state its in for its year is mint most of the peoples cars on here are imaculate and more like brand new rather than mint Mint on PF is a bold statement and paraps i should have worded what i said a little diffrent
the buying it in the dark again was stupid but as i knew what i was going to look at and tok his word for what the car costs and what the guy sold it to me for and the year he sees no wrong other than the oil leek what ive had an appoligy for
not making excuses like you said you get what you pay for saying that other than the few minor inperfections the car is mint! well in my eyes anyay
Right back to the Thread
Old Feb 27, 2007 | 05:50 PM
Dan's Avatar
Dan
You live and learn mate don't worry!
Shitty little bits like splitters and interior parts can easily be rectified!
You've done one thing right and that's not pay over the odds for it, for 9k you've got 6k+ to spend before it's in the league's with proper modded Escort's IMO so imagine what it will be like then!
As said, best of luck with it!
Old Feb 27, 2007 | 05:55 PM
Gatecrasher
Not welcome...
Not sure if im gonna take it to the shows i would feel a bit silly as its not really a show car its more an everyday car
Am keeping the Morretts mate just new Diamond lenses
Good luck finding one i love mine
cheeRS Stu
Nice one stu cheers mate
Dont worrie me obliterating him and his M3 in my Escos will be pain enogh for him he just cant see why i want a 14 year old car to him cars a car
Thanks for all the replys just went and took a few more picks of the car and got some of a few other bits more to follow shortly
Old Feb 27, 2007 | 05:58 PM
Gatecrasher
Not welcome...
thats what i was thinking looking more like 10k tho and thats on the standard Block and head wont be to long for it shits itself with 400ish hp running threw it
Old Feb 27, 2007 | 06:11 PM
Alan s1's Avatar
Alan s1
If it makes you feel better i did the same with my saph off a m8 he had it for some time i had'nt seen the car for some time due to moving 100miles away and when it came up for sale i jumped @ it
It had more bits wrong with it then i was told but sorted things out as tbh it was cheap IE like your Escos was cheap Now its been off the road for some time BUT im buildong it to how i want it
Old Feb 27, 2007 | 06:17 PM
Gatecrasher
Not welcome...
right getting back to the engine
Having a Grp A T34 with a Maram shaft thought i may aswell put it to use sent the ISCV to be modified Again Mikes sorting that out
Got myself a Anti lag throttle body, not sure what that sensors for anyone?
Also to take care of the cooling side of thing is spent a few quid with Dan@rapid-ford just waiting on my 500 cooler and turbo prerad
As you can see from the pics i went for apple Green Samcos to they are all thats holding me back as they had to be made where there isnt a great calling for apple green never mind at least know there wont be many about like mine got a 19 row oil cooler to help keep things cool if it was one thing i lernt from my Escort turbo its that Turbo Cars Get Hot and HOT means Melting, MELTING = Not Good
Old Feb 27, 2007 | 06:19 PM
KSA-Cossie's Avatar
KSA-Cossie
The spending commences.
Old Feb 27, 2007 | 06:28 PM
GazzaG's Avatar
GazzaG
Old Feb 27, 2007 | 08:33 PM
baggydog's Avatar
baggydog
Old Feb 27, 2007 | 09:10 PM
Gatecrasher
Not welcome...
Tell me about it be worth it in the end tho
Last couple of pics i took set of pullys i got for when it goes to Stu@MSD for mapping to get that perfect Collaboration of parts
new front and rear lenses to really freshen up the look
and the last one untill it starts going back together is its current state tonight
Thanks for all the replys and support will keep you posted on progress and parts as they arrive and get put on the car
Anyone like to have a stab at what power they think i will get please feel free
Old Feb 28, 2007 | 08:14 AM
Nice to see the car getting the bits and bobs,also good to see the interior bits going ,love the new rear lamps will work well with the colour ,and what new wheels are you getting ,we was always telling ravi to replace them when he owned the car ,dont suit the car imo
Old Feb 28, 2007 | 09:17 AM
Gatecrasher
Not welcome...
I dont like them that much 17's aswell, tyres are pretty shot to bits so it will probebly get a new set of treds before it goes back on the road!
I was intrested in Speedline chronos 18 or 19inch but they was £2000 a set with 3 set minimum order lol
Probebly the new compo Mo6's or i quite like the look of the CTX wheels, bit limited to what you can have due to the ET being 15
thanks for dropping in tell Ravi his old cars getting a revamp
Old Feb 28, 2007 | 09:52 AM
Brian's Avatar
Brian
Brian
Old Feb 28, 2007 | 09:55 AM
Gatecrasher
Not welcome...
hey Brian
Mike Rainbird Has just sent me some Pics of my Parts going to the Paint strippers to be repainted in GREEN
Propper shame as it all looks so good!!!
Still it will look even better in green
Old Feb 28, 2007 | 11:24 AM
G1EN's Avatar
G1EN
Looking good fella. Good to see its getting the treatment it deserves.
Didnt realise this was Ravi's old car.
He a m8 of mine too.
Hows the Steering whee, did you maange to get the part for the horn that goes on the back of the wheel?
Old Feb 28, 2007 | 02:37 PM
M K's Avatar
M K
cor you weren't lying when you said you'd been on a spending spree
glad to see it all coming together for ya now, gonna be a corker when its done
Old Feb 28, 2007 | 05:33 PM
Gatecrasher
Not welcome...
Hey glen sort of got the new wheel fitted done my nut in for a bit till i realised it has an internal part that has to come out
Thanks for stopping in any luck with the hunt for a grey one?
hows it going mark got your new Turbo yet?
yeah the spending is a nightmare there is allways a nother little summin that leads to somthing else and so on
CreditCards Maxxed = Yes!! Eating into Savings = Yes!! Gonna keep spending = erm probebly
Old Mar 1, 2007 | 11:15 AM
Franco's Avatar
Franco
Ahh so your the fella who wanted the gauge pod!
Good post mate, its a slippery slope you're on thats all i'm saying!!
Mines started off as a freshen up (couple of months max) to alot more intense and about 8 months overdue!
Keep at it though!
Old Mar 1, 2007 | 11:22 AM
Ryan's Avatar
Ryan
glad the trousers are good.
Old Mar 1, 2007 | 12:15 PM
M K's Avatar
M K
yeah i picked mine up yesterday mate, had to have the actuator bracket moved again tho
Old Mar 1, 2007 | 01:21 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Ben,
There's a reason not many people go for the lime green hoses - .
Old Mar 1, 2007 | 07:30 PM
jameswrx's Avatar
jameswrx
Didn't live in tenterden a few years back did it?
Old Mar 1, 2007 | 07:39 PM
Gatecrasher
Not welcome...
Ben,
listen mike! just because you powder coated everything blue dont mean you have to come on here and have a pop at me i told you i wanred green coz my cars GREEN not Blue GREEN
anyway if it wasnt for that stupid Cam cover pic on your website i wouldnt have even gone for GREEN and probebly stuck with Blue
if i was to get the same colour hoses as you i may as well go back to standard colour, paint my car white, stick a on my head and chage my wheels to Gold :gayflag:
serious tho wait till its done i have a vision
its blurry
Old Mar 1, 2007 | 07:43 PM
Gatecrasher
Not welcome...
looks naughty mate
fancy a swap
look forward to seeing you out in it
Old Mar 1, 2007 | 07:45 PM
Gatecrasher
Not welcome...
Couldnt tell you i brought it from Becton East london
Old Mar 1, 2007 | 07:56 PM
TimC's Avatar
TimC
doing well there. gona look mega compared to when you got it
Old Mar 1, 2007 | 09:40 PM
Mike Rainbird
Caraholic
Ben,
Try Spec-savers !
Old Mar 1, 2007 | 09:47 PM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
well smart , gotta agree with Mike homobird tho lime green
keep it up mate
Old Mar 1, 2007 | 10:00 PM
dave cos4x4's Avatar
dave cos4x4
looking good,plenty of nice parts.
Old Mar 2, 2007 | 12:05 AM
Gatecrasher
Not welcome...
Ben,
Try Spec-savers !
why is that where you get your frames from Randbum?
anyway whats them GOLD Subaru Impreza wheels all about see your sidekicks having a pop at my Apple Green Hoses think his bad boy bonnet crew over at FiestaTurbo.com been bigging him up a bit to much nice escos btw
Apple Green thats better like my Cam cover and bit you fucked up mike from now on my hoses are apple green im righting samco to tellem!
Cheers for stoping in dave im having a good go
Old Mar 3, 2007 | 01:05 PM
jameswrx's Avatar
jameswrx
Thought I reckognized the plate that's all.
A girl round here had one that looked very similar, was running Graham Goode conversion, but it was a while ago thinking about it.
Old Mar 5, 2007 | 07:51 AM
alanfordtw-15's Avatar
alanfordtw-15
looks cool, that car Was mint for the money, mine was similar money but a fair few more things wrong with it ,small stuff though, easily fixed, the car is fundementally perfect, but then two of us spent an hour inspecting it inside out- in the light
i wouldnt give your 'mate' the time of day, sounds like jealous bolox talk, i get it too, "that must drink petrol " is the big spoiler for pushing it" ect. grumpy fuckers cant stand seeing a twenty year old with a better car than they've ever had or will
Old Mar 7, 2007 | 06:29 PM
Gatecrasher
Not welcome...
not this car as it had been done by grove/ahmed to stage 3
see what he says when its done
