escort si tuning?
it is and using just bolt on parts too.
my gti is running 150 Bhp with 140 ibs tourque.
spec is:
2.0 maf, throttle body and cams
k&n apollo cis induction kit
ashley 4-2-1 manifold (de-cat)
magnex catback
uni-chip
have a look on ebay for the ford parts. very easy to come by.
but to be honest with you. the money i spent getting to that mark could have been spent to put a 2.0 liter in. my next thing on the old "to do list"
spec is:
magnex catback
uni-chip
spec is:
magnex catback
uni-chip
spec is:
magnex catback
uni-chip
As he said ^^^^
Lip,
There is no point doing anything to the 1.6 ZETEC it will cost a fortue to get any extra BHP.
150 bhp is easy from a 1.8 ZETEC. Just fit 130 bhp spec cams and a megasquirt. No need for chips, induction kits, exhaust and MAF changes. Keep it simple.
Originally Posted by Wardy257
Lip,
Been following this topic myself. I have an Escort 1.8 Ghia Si. It's only the 105PS version on the 1.8 16v DOHC (not the zetec)
How easy would it be to get a few more BHP on a shoe string budget?
The waterpump changed with the Blacktop ZETEC. Your is a Silver top if it has DOHC so they were probaably making sure.
The ZETEC was originally called the ZETA as was going to be a carb enigne from 1.4 to 1.8ltrs.
What like? Forgot to mention you might need a slightly larger TB off a 2.0.
[quote="munzygti"]it is and using just bolt on parts too.
spec is:
magnex catback
unichip
My Cat Is On My front pipe on my escort Si who did you get your 4branch manifold from? Mine Is an N-reg!
spec is:
magnex catback
unichip
where are you all getting you power figures from 150bhp GTi from a chip and breathing mods would love to see you power graph please
and wardy 130 spec + ms = 150bhp seems a touch optimistic... its that on a stadnard HO manifold or the ultrarare oversized ported one?
your is a zetec it just has a different rocker cover, the engines the same
for zetec mods on a budget, i found the decat the best bang for the buck. had to put a cat on my old (standard-ish) 2.0 zetec mondy for the MOT and it felt so much slower compared to with no cat!
induction kit makes it a bit quicker at mid-high revs but at the expense of power lower down (can make it feel sluggish around town).
another cheap easy power upgrade to do is underdrive pulley.
lightened fly helps alot on the zetec too.
not being funny but surley the easiest way would be to put a 2 litre in and build on that,i would have thought this would have been a good starting point?
Also tried putting a 2 litre throttle body on my 1.8 si and found all it did was make the A pedal sit lower and drink copeus amounts of fuel not impressed
But then someone told me thats because i didnt use a cone filter as ive still got the air box on but its just been drilled
A 4 branch will do very little unless it a properly designed (ie expensive one) even then you will need an ECU remap.
Induction kits do b#gger all, they lose power if anything.
how big can you go on the throttlebody witouth the fuel dropping out the inducted air?
Dr. Ickxs
Sep 15, 2015 10:15 PM
