Cossie tappets
Old Feb 23, 2007 | 11:43 AM
Default Cossie tappets
Hello there im gonna b changing my tappets on my saff cos 4x4.is there a proper way of changing them.eg do u have 2 compress the oil out of them before u fit them.Im changing the timing belt n tensioner 2.
Old Feb 23, 2007 | 12:30 PM
IANS2RST's Avatar
IANS2RST
i just dropped mine coated with plenty of oil.
makesure u use genuine ones made by ina as non genuine don't last long
Old Feb 23, 2007 | 02:33 PM
Alvyn's Avatar
Alvyn
drop them into a bucket of oil o/night and fit them wet would be the way I'd do it!
Old Feb 23, 2007 | 05:20 PM
As said defo make sure at least outside is lubed with oil, may as well do cam seals while there ?
They do not have oil in them when new so will pump up normal way when engine starts.
Old Feb 23, 2007 | 05:24 PM
The new tappets i have r made by the british gaskets group i got them months ago. The only reason why im changing them is cause when i first start the car its quiet but give it about 2to 3 minutes n they start tapping. im using castrol rs oil 10/60.Its not cause of the oil is it.
Old Feb 23, 2007 | 06:18 PM
cozmeister's Avatar
cozmeister
More boost Igor!
That's what mine does Then it goes away again, right?
It's better after having the filter done though. Also have a new set of tappets, might even get round to fitting them one day! The actual removal procedure's in the Workshop Manual - have you got a copy?
Old Feb 23, 2007 | 06:28 PM
Well i wonder if changing the tappets the noise will go away. I hope so yeh ive got 1 of those work shop manuals on cd.
Old Feb 23, 2007 | 07:27 PM
A lot do it on castrol rs, that is why I stopped using it.
Tappets seriously easy to do but long job, cam pulleys off, cams out etc so might as well do cam seals at same time, make sure you use VITON ones as they need to be this because of heat.
I am doing this shortly, as head off.
You can remove the cams without disturbing pulleys but there is a little metal tiny bracket behind each one which can bend, woodruf key also needs pulling to do seals from both cams.
Old Feb 23, 2007 | 08:51 PM
I was thinkin it might of been the oil cause when i first bought the car it never did it but since changing the oil it always done it.what oil do u use.My car will b due a oil change soon.
Old Feb 23, 2007 | 08:55 PM
KSA-Cossie's Avatar
KSA-Cossie
Guarantee you it's the oil m8,try using silkolene pro s 15/50
Old Feb 23, 2007 | 09:07 PM
Well i might just buy some new oil n try that.I thought it might of been the oil cause normaly when tappets r worn they normally rattle when u first start the engine n then the oil gets in the tappets n the noise goes away.
Old Feb 24, 2007 | 07:51 AM
I use when I can get it SUNOCCO RACING 15/50, but if not, silkolene pro s is very very good IMO.
Old Mar 16, 2007 | 02:25 PM
I bought some silkolene pro s 10w 50 oil today.Will this b ok for my cossie i cudnt c any 15w 50 in the shop.
Old Mar 16, 2007 | 02:26 PM
It will be perfectly ok, just a tad noisier on start but with new tappets unlikely to notice anyway.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
davidfordrs
Sep 21, 2015 04:23 AM
