How difficult to change engine mounts
Old Feb 23, 2007 | 09:56 AM
Mathias's Avatar
Mathias
Default How difficult to change engine mounts
HI!
Is it difficult to change the engine mounts on a 4x4 Sierra Cosworth?
Old Feb 23, 2007 | 11:22 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Standing in front of the car then the right hand side is not to difficult to change. Remove the inlet hose from ic to trottlebody to get more clearance. I cant remember if the trottle body itself also has to be removed (I think i did), but that's only four 8mm screws. Unscrew the 19mm bold from the engine mount and than jack up the car. There should be enough clearance to unscrew the other two bolds (thought they were 13mm) and then change the mount.
The left hand side is another story. Since you cannot jack the car far enough there is no clearance to get the old mount out. So you will have to remove the engine mount holder that is connected to the engine aswell. This is hold by four 10mm bolds but can be hard to loose. Only use a tool with 6 flacks in it not the one with 12 (dont know how to explain it in good english) or you will damage the bolds. That's how I did it, don't know if there's a better way.
Good luck.
Old Feb 23, 2007 | 06:53 PM
Mathias's Avatar
Mathias
Thank you for the info. Started already with the job and hopefully
will finish tomorrow.
Red_bull
Aug 25, 2015 06:27 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
lockie
Jul 31, 2015 10:03 PM
