Understanding rear suspension on a FWD car
Not a Ford I know, but I am looking in to different options for the rear of my 205 and I guess the effects are the same for any FWD car.
I have the following information courtesy of the 205gtidrivers website, but I was wondering how the rear toe in and rear camber affects handling and how to understand these figures:
How does the degrees/minutes work in this case? Which of these has the most camber?
On a purely track car running slick tyres do I want 0mm toe in (so the rear wheels run parallel) and as much camber as I can get from using the standard components above?
Originally Posted by Turbosystems
the one with the bigger numbers it is that simple
I thought that was kinda the case but from what I read people said the ZX arms had the most, but they were 1/00 so infact, they didn't!
you can read all the theory and opinions about settings all you like, but it's how they feel to the way that you drive that is important.
some people like the back end to move more than others, some have a quicker turn in etc.
xr4x4rs
Aug 6, 2015 09:03 PM
Graceland
Jul 31, 2015 10:34 AM
