water testing ????
its looking like im going to need to free up some cash very soon
so im just putting a taster together to see if PF has any one with actuall cash to part with or does it go on ebay in bits ???
the items ...............
incl trailer
a large iveco 3.5 ton van (51 plate)
and an absolute garage full of spares (multiplate clutches/shafts/turbo/engines/gearboxes/diffs/steering parts/ecu's)
all for sale to the right bidder !!!
incl trailer
Originally Posted by RONNIE AMIS
cant you break it and sell me the cage?
itt will come wrapped in a nice 3door shell though , is this a problem to you >?
Shame, but I bet there are a whole load of juicey bits on your car I could do with
Have you tried the obvious places for selling the car? Racecar forums etc...?
If you break it you'll have a couple months of hassle, but possibly a lot more money than selling it whole.
Fancy cobbling together a spec list for the car?
Si
Si
heres a small list of bits without much detail though tbh
shell incl pedal box
fuel tank
strut brace front
engine
ally header tank
4x4 starter
exhaust system 3"
remote oil filter/cooler
4wd quaife big tooth
qauife sport gear shift ally
rear diff assy
std front shafts
std front diff and plate
front prop thick x2
front prop thin
eng loom
3 bar map sensors x2
radiater radtec
steel crossmember 4x4
intercooler
turbo T34 marm
std T34
injectors grey
air injector kit
seats sparco
seat belts 6point
fire extinguishers x4
eng monitor
ecu P8moded
ecu std P8
ecu std L8
ecu std L8
als valves x2
front shockers bilstein 41mm
rear shockers bilstein 41mm
front hubs 4x4
tca's adjustable
comp struts
prop
breather
pas pump
rack with screw on fittings
fuel pump (lift)
fuel pump high
fuel swirl pot
forrests x 10 205/65/15
slicks x 10
team dynamics 9x17 x 5
compomotive 15"x7 x 8
dash guages
kevlar bonnet
17" leagues x 6
ap front brakes bells discs
rear discs calipers
generator(big)
peltor intercom
twin plate 7.5 clutch
triple clutch no plates
7.5" ultra light flywheel
fuel rail
coil and leads
alternators x 2
strut bodies front x2
trailer
van
various springs
fuel tank
strut brace front
engine
ally header tank
4x4 starter
exhaust system 3"
rear diff assy
std front shafts
front prop thick x2
front prop thin
eng loom
radiater radtec
intercooler
turbo T34 marm
std T34
injectors grey
air injector kit
seats sparco
seat belts 6point
eng monitor
ecu P8moded
ecu std P8
ecu std L8
ecu std L8
als valves x2
front hubs 4x4
tca's adjustable
comp struts
prop
breather
pas pump
fuel pump (lift)
fuel pump high
fuel swirl pot
slicks x 10
dash guages
kevlar bonnet
17" leagues x 6
rear discs calipers
generator(big)
peltor intercom
fuel rail
coil and leads
alternators x 2
trailer
van
various springs
I'll take the lot.
Ta.
On a more serious note though, I'd love a SECS monitor if that's what you have.
And the 6 points if they are tidy.
And if I remember correctly, you posted a pic with a front mounted ARB - was that yours? I have the compression struts, but could do with the front mount ARB and crossmember if you have it.
Si
Ta.
Si
Originally Posted by SiB
I'll take the lot.
Ta.
Si
Ta.
Si
not secs but collins, but that salready reserved im sorry , as for the rest i think bidding is best .................................................. ........soon !!!!!
Mark RS
Oct 12, 2015 06:01 AM
