SECS ECU has landed as promised
Old Sep 10, 2004 | 11:10 AM
Ima-Racing500's Avatar
Ima-Racing500
Default SECS ECU has landed as promised
Not that i didnt trust your word Simon..ROFL
So i can now get the final specifications sorted
Simon,if you read this,can you just confirm that the base chip will be ok using the EEC4 TPS????Or do i have to use the PF 4X4 TPS?????
Oh and also has this got boost control...ie varied instead of justa flat boost curve???
Thanks alot...appreciated.
Old Sep 10, 2004 | 11:11 AM
Spiky's Avatar
Spiky
Greg Shepherd's Avatar
Greg Shepherd
Chasing Radders
Old Sep 10, 2004 | 11:18 AM
ECU Monitor Enthusiast
Phil,
I am SOOOOOOO glad Royal Mail didnt lose that package.
Regards TPS, you can use the EEC4 tps (ECU config as 4x4 cossie) but you may need to adjust the zero point mechanically.
I am just about to release a version of software that alllows software recalibration
of the TPS.
You may or may not need this but lets see how it goes.
As for boost control, Yes there is a fully mappable boost controller built in
using either the standard AMAL (Escort type recomended) or
using (YAWN) air injectors or a high speed generic control valve (E.G Greddy).
Old Sep 10, 2004 | 11:25 AM
Ima-Racing500
Simon does this mean that if i use air injectors i can say program the ECU to give different pressures at different RPMS????
Old Sep 10, 2004 | 11:29 AM
Porkie's Avatar
Porkie
Phil, yes! well I hope so because thats what I need doing on mine.
Simon could you send martin the software update please as we are putting the air injectors back on. Thanks
Spot on Phil,
PLUS you can map against throttle position to get a slower
(or faster if you really want) spool up when just cruising along.
This also can aid when a turbo SURGES badly on part throttle positions.
Old Sep 10, 2004 | 11:30 AM
Porkie,
Its on its way Lee
Old Sep 10, 2004 | 11:31 AM
Ima-Racing500
So the MD240R or a T4 will be now usable for me.
Porkie's Avatar
Porkie
Cheers mate!
Old Sep 10, 2004 | 11:39 AM
Rene's Avatar
Rene
Old Sep 10, 2004 | 11:41 AM
I use a MD240 (a copy of it) and I have NO surge at all !
Have also done a few T4's but they are quite stable in most cases anyway
from my experience.
You also do NOT need to have air injectors unless you want to pay loads
and want the bling effect.
The standard escort cossie amal valve works just as well.
I did not believe this until a well known tuner proved it to me.
Its good that other tuners are feeding back info to me to help with
product improvements and features.
About bloody time
Old Sep 10, 2004 | 11:44 AM
Ima-Racing500
I supply air injectors so they are cheap to me..LOL....on my old conversion running saff amal i had surge issues from 4th gear at 4500rpm to 6000rpm....
Old Sep 10, 2004 | 11:45 AM
Stu @ M Developments's Avatar
PassionFords Creator
Looking Good
Old Sep 10, 2004 | 11:49 AM
Phil,
The problem is with surgy turbos, its a compromise between power and spoolup time.
Its is not always to possible to map out surging but you can usually reduce its effects.
I am NO tuning expert so you may have to consult an expert about
turbo choice as engine spec also can affect it !
Old Sep 10, 2004 | 12:32 PM
Ima-Racing500
Simon...i found on the T4 i could run without surge at about 24psi after that then probs..i had an in car controller manual one and if i turned it up above 6500rpm approx it was fine.
Still considering turbo.
Ima-Racing500
PS is it gonna stop working after 3 months????
Old Sep 10, 2004 | 12:34 PM
Rene's Avatar
Rene
LOL
Old Sep 10, 2004 | 12:40 PM
Phil, All products carry 1 year warranty (on a return to base basis)
Assuming they have not been incorrectly used or abused.
At this point in time, I can honestly say NO ecu's have failed in any way.
I charge a fixed fee for repair of any product when out of warranty.
Also, I can arrange for a small fee, on site repairs or exchange but this
depends where and who you are !
Old Sep 10, 2004 | 12:42 PM
Spiky's Avatar
Spiky
think he means after his trial si
Old Sep 10, 2004 | 12:47 PM
Ima-Racing500
As Spikey says!!!!!
Old Sep 10, 2004 | 12:55 PM
Phil,
Details for your free trial.....
There is a 20 hour time limit set up in your ecu.
After 20 hours of engine run time,
you will get a fault code set saying you have 2 hours more run time left.
After a total of 22 hours run time, the ecu will force a non reversable rev limit to
3500 rpm, 1 hour later the engine will stop and NOT start again.
You cannot bypass this by disconnecting the battery as the ecu does not
require power to maintain its memory. (FLASH TYPE MEMORY TECHNOLOGY)
Nor is there a back up battery inside the ecu.
Only by entering a security code once purchased can this be disabled.
Sorry I had to do this but, I sent an ECU to a well known tuner 5 months ago when
he said that I would get paid within a week.
Still waiting for payment and he ignores my calls !
I know for a fact he sold it on to a 3rd party who is very happy with it.
Old Sep 10, 2004 | 01:03 PM
Ima-Racing500
LOL...........i take it that i WONT have to send it back to you to get working?!..I pay and you give me the code inwhich i can un disable it via a laptop?????
Aslong as its that easy i DONT mind that you have insulted me..ROFL
Old Sep 10, 2004 | 01:06 PM
Phil, Yes the unlocking can all be done by yourself with a laptop.
Sorry, No insult intended (This time )
Old Sep 10, 2004 | 01:17 PM
Originally Posted by SECS
Phil,
Thats more impressive than the ecu...
Old Sep 10, 2004 | 01:21 PM
zvhturbo's Avatar
zvhturbo
Unless you have the ability to write a program that can extract the pasword from inside the ECU
Old Sep 10, 2004 | 01:25 PM
As each ECU is electronically serial numbered, the program and its data
including the MAPS are scrambled/encrypted uniquely for every ecu.
You may spend 6 months reverse engineering the code/data for
information but it will only work for that ecu.
I have thought about hackers.... I used to be one
Old Sep 10, 2004 | 01:32 PM
zvhturbo's Avatar
zvhturbo
Then you should know there is always a way??!!
I'm sure you have a programe for your use?
Old Sep 10, 2004 | 01:33 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Old Sep 10, 2004 | 01:39 PM
zvhturbo,
Nothing is ever 100% secure but you can make it beyond economical
work for most people but I suppose there will always be hackers who do
it just for the hell of it.
Anyway, if my system is compromised, I can change it any time as all the software
on the ecu is upgradable at any time even when the car is running. !
Yes you are right I do have a program to do it but then I designed the whole
thing so I should know how it works.
Old Sep 10, 2004 | 01:43 PM
Dave Henshall's Avatar
Dave Henshall
rollon october - i cant wait for the pectel compatiable version of the secs monitor
Disabled Account's Avatar
Disabled Account
How clever is Simon?..................VERY
Old Sep 10, 2004 | 01:55 PM
JAP CRAP's Avatar
JAP CRAP
yep, very clever
Simon. You shouldnt have told Phil Then when he called you to say he was stranded, forced his credit card details off him for you giving him the code in return
Old Sep 10, 2004 | 02:03 PM
JAP CRAP, I am sure Phil is an honest person
Old Sep 10, 2004 | 02:05 PM
JAP CRAP's Avatar
JAP CRAP
I'm sure he is . Still would have been the more amusing way
Old Sep 10, 2004 | 02:11 PM
GARETH T's Avatar
GARETH T
massivly impressed simon! ummm now with i had a car so i could have a nose round onw
Old Sep 10, 2004 | 02:15 PM
Malc50's Avatar
Malc50
Hi Simon....
A bit off topic but any news when your new monitor will be available???
Thks
Malc
Old Sep 10, 2004 | 02:32 PM
bbigman2000's Avatar
bbigman2000
amazing stuff, look forward to hearing how it works, certainly a better prices than autronics
Old Sep 10, 2004 | 08:19 PM
Originally Posted by Malc50
Hi Simon....
Thks
Malc
NEW ECU MONITORS
I am in the process of construction a website for the new monitor
and I will announce it on a thread VERY soon with some preview
pictures. Sales should start end of this month.
May even organise an initial group buy.
It has a large vacuum flourescent display (BLUE),
displays graphs and scalable fonts for numeric data (up to 16 items on a screen),
does data logging, compatiable with all cossies including EEC4 and pectel ecu's.
(uses either direct reading or serial data link option)
Also does jap cars PLUS VW, BMW, AUDI, SEAT, SKODA, etc.
Will also work with Motec, OMEX and Autronic ecu's
Can add external sensors such as oil pressure, oil temp, fuel pressure and EGT.
Will be sold through limited dealers !
Price - Cheaper than you think.
Please dont ask me for more info just yet - Please wait for the thread
Also available soon, 10.4 inch TFT COLOUR LCD monitor with touch screen
and software to create you OWN screens. Dials, bargraphs, animations
bit maps etc.
For the more dedicated car owner......
It will be worth the wait........
Old Sep 10, 2004 | 08:34 PM
Malc50's Avatar
Malc50
Simon...
Ok great, end of the month it is then....
Thks
Malc
