getting x-box 360 connected to net
right im having bother connecting my 360 to the internet,got the router and the ethernet cable,passes the address ,then fails on MTA,any body no what i can do to get it online?,cheers.
I think you have to ring bt up and get them to open certain ports on the router to allow you to get the 360 online, I'm not sure, my m8 had to ring them up to get limewire working
Originally Posted by BUFFTY MIC
its a bt openworld ewire router
Give your Xbox a static IP and set it up as the DMZ host
When when you go into a router, you have two networks - the external one (i.e., the Internet) and your internal network (your computer, your router, your xbox etc). If Xbox Live wants to send data to your Xbox, it has to rely on the router to figure out where to forward the traffic to. This is where Network Address Translation, or NAT, comes into play.
By putting your machine as the default DMZ host, you have a fallback - if the router doesn't know where to send the data (which can happen for a number of reasons), it sends it to the DMZ host. By default, this is the router - so if it doesn't know where to send the data, it basically eats it.
I setup xboxs as I stated with a static IP and can set the MTU in your router settings... the ip address for the router should be on the bottom of it... you can bring up the configuration by typing this in a web browser ( example http://192.168.0.1 )...the username and password should be on the bottom of the router also if it has not been changed
Xbox Live requires a minimum MTU setting of 1364. If your console does not pass this test, you cannot sign in to Xbox Live.
If you have multiple consoles that are connected by using the same connection, you may cause a failed MTU tests. A failed MTU test may also be caused by sharing the connection with a computer.
Im assuming that you have a WindowsXP pc connected to this router when I say the following
if you go to 'run' and type 'cmd' the command prompt windows (black box) should then show.
in this window type 'ipconfig' this should then list your network configuration... the ip address for your default gateway should be displayed.
This is your router ip address, type this into your browser ( ie http://192.168.0.1 ) you should then be prompted for the password, the default user is usually 'admin' or 'user' and the password 'password'
you should then be able to see your router configuration
23
Sep 12, 2015 12:56 PM
atm
Sep 1, 2015 04:56 PM
Sierrasideways
15
Aug 31, 2015 10:10 AM
