how much psi is 1.5 bar
Old Feb 20, 2007 | 07:45 PM
saph4be's Avatar
saph4be
Default how much psi is 1.5 bar
as above how many psi to a bar
Old Feb 20, 2007 | 07:46 PM
bud-weis's Avatar
bud-weis
Football Cwazy
22psi or thereabouts.....
Old Feb 20, 2007 | 07:53 PM
big_wig_074's Avatar
big_wig_074
for ease of maths call it 15psi to 1 bar mate.
its actually 14.7psi at sea level. 1 bar is one atmospheric pressure
Old Feb 20, 2007 | 07:55 PM
saph4be's Avatar
saph4be
i run a t34 on my cossie it peaks at 1.5 bar then levels off at about 1.6 does this sound about right it has 500 intercooler light blues and made 379 on a dyna pack what is the max for a t34
Old Feb 20, 2007 | 08:24 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
How can it peak at 1.5 bar and then HOLD 1.6 bar ?
Good power for the boost
Steve.
Old Feb 20, 2007 | 08:40 PM
rssteve's Avatar
rssteve
maby he means it peaks at 1.6 then holds 1.5
Old Feb 20, 2007 | 09:49 PM
saph4be's Avatar
saph4be
sorry peaks about 1.5 and holds about 1.3
Old Feb 20, 2007 | 09:59 PM
bud-weis's Avatar
bud-weis
Football Cwazy
well it sounds a little low for the spec,certainly too low to make a genuine 380bhp....i'd expect it to be nearer 2 bar for that..
Old Feb 20, 2007 | 10:03 PM
saph4be's Avatar
saph4be
will have to get it cheked out dyno print out is only about 1200 miles ago now i worried
Old Feb 21, 2007 | 06:09 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
With light blues (400s) you should be able to peak at about 2 bar and hold 1.7 - 1.8 bar.
What exhaust housing is on your T34 ?
Your car will not make 379bhp peaking at 1.5 and holding 1.3, sorry.
Steve
Old Feb 21, 2007 | 07:17 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
http://www.google.co.uk/search?hl=en...G=Search&meta=
that says 1bar is 14.5037738psi not 14.7 as quoted.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
155lee
Oct 24, 2015 11:11 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Tony W
Sep 9, 2015 12:08 PM
