6 bar of fuel pressure???
Today I go to see how much I have fuel pressure, and I have about 6 bar in idle!
is this normal? mechanic told me that I must put hose from fuel press regulator, to vacuum (inlet plenum) to lower the pressure.
thanks
thanks
Base fuel pressure should be between 5.7 and 6 bar. The control pressure (the pressure inside the meter unit) will be around 3.7 bar at 6 bar base pressure. It's perfectly normal as the system needs this pressure when on full boost/load.
JK12
33
Apr 26, 2021 12:09 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Tony W
Sep 9, 2015 12:08 PM
