Gearbox/clutch problem, please help
Old Feb 19, 2007 | 08:23 AM
matts1's Avatar
matts1
Default Gearbox/clutch problem, please help
Hi,
I have a problem with the clutch on a 1.8 TD N plate escort.
The clutch arm on the gear box is loose, it attached to the gear box on a spline that comes out of the box.
It is secure to the spline, but the spline itself is loose and wobbling about
There is also vurtually no clutch pedal, tiny bit, and it vibrates when pressed down?
Do I need to replace the clutch, and this spline thingy, can it be fixed without removing the box?
Please let me know if you have any idea's.
Matt
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
