OPPS (ENGINE NUMBER 2 DEAD)
Feb 18, 2007 | 06:58 PM
Feb 18, 2007 | 07:00 PM
Feb 18, 2007 | 07:03 PM
it made a very big bang and locked up both front wheels it put a hole in the front and back of the engine i only had to remove 2 bolts to remove the oil pump
Feb 18, 2007 | 07:05 PM
ouchy...
Feb 18, 2007 | 07:28 PM
what happened? ecu failure? injecotr stop working?
Feb 18, 2007 | 07:31 PM
ecu went faulty it was putting to much advance on the timing at a bar of boost
Feb 19, 2007 | 01:23 PM
Feb 19, 2007 | 01:54 PM
Feb 19, 2007 | 05:32 PM
Feb 19, 2007 | 05:59 PM
Feb 19, 2007 | 06:13 PM
sound system now sold and new engine build has started also going efi as well
Feb 19, 2007 | 07:06 PM
Why do you say its the ecu's faulty?
and not a map issue, or too much boost for map?
Feb 19, 2007 | 07:33 PM
I must admit i was wondering how you've pin pointed the fault so accurately
Feb 19, 2007 | 07:46 PM
i sent the ecu off for testing and thats what thay come back with
car was set up by p/e
base timing was set to 10*c btdc co set to 2.5% at idle and running 1 bar of boost
was and i mean a big was running 168bhp
Feb 19, 2007 | 08:13 PM
Who tested it? and how?
ps ECU failure like this is un common, infact i've never heard of one, usually down to mapping/boost or sensor/fuel pump/inj/wiring fault.
Feb 19, 2007 | 09:07 PM
atp are who tested the ecu the ecu was from ebay i fitted it then got it set up when it happend i was only doing apx 60 to 70 mph on a motor way going up hill and not giving it beans the car has also had fitted new fuel pump and injectors dissy cap and rotor and a dissy
i dont know how they can tell if its faulty but they have the test equipment
also the engine had been rebuilt just before i got the car
who knows????????????????
Feb 19, 2007 | 09:11 PM
could of been mapped for a low comp motor
Feb 19, 2007 | 09:43 PM
it was a power/e chip (black chip )which was on the chip itself
pass on the spec
Feb 20, 2007 | 08:15 PM
""car was set up by p/e
was and i mean a big was running 168bhp""
then what was problem? ecu putt to much advance on timing? arent you feel that car is going different than before?
Feb 20, 2007 | 08:18 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Rod-Tarry
Aug 27, 2015 10:12 AM
dingla rs
Aug 24, 2015 11:52 AM
andy130
29
Aug 12, 2015 05:59 PM
