100k service on escort mk6!
Right my escort is due to hit 100k soon and i want to do a bloody good service on her, its my daily runner and does me proud! its a escort si 1.8 (115bhp)
i normally oil changed it bout every 10k but thats bout it! Gotta lil list of things im gonna do, have i miss anything?
Cambelt
Alternator belt
Filter's Air, oil and petrol
Spark plugs
Oil
Change cooling water
Change brake fluid and bleed brakes, (changing rear shoes any how)
Also thinking , not sure if its worth it: Injector's cleaned!
Any think esle i sould consider?
Cambelt
Alternator belt
Spark plugs
Oil
Cabin filter (If it has one)
Injectors dont normally need cleaning. Unless you have a problem I would leave them alone . Dont forget to put the cam belt tentioner and idlers on,
Dave
Dave
Dave
Dave
its called a pollen filter it filters the air coming into the car it is better to change these too also check the wheel bearings flexi pipes you could change the g/b oil too it depends how far you want to go into the service
dont forget to check the spare tyre
