efi technical q
Old Feb 18, 2007 | 12:42 PM
ian r's Avatar
ian r
Default efi technical q
how do i test to see if my co pot is working
Old Feb 18, 2007 | 01:33 PM
Rick's Avatar
Rick
put a voltage across the outer 2 pins.
Then measure the volage between the middle pin and either of the outer pins. Adjust the screw and see if the voltage changes.
Old Feb 18, 2007 | 04:25 PM
Just do a resistance test across the pins whilst turning the pot, this way you can check for any dead spots also.
Old Feb 18, 2007 | 04:41 PM
SafeChav's Avatar
SafeChav
I also would say resistance test.
mk1turboestate
Dec 2, 2015 08:31 PM
Sep 18, 2015 02:27 PM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
Shows & Track Days
Sep 4, 2015 07:16 AM
