Bought new springs, which is the top????
Originally Posted by Maxfield
Originally Posted by Andy_R
Whats that in the middle Spiky?
I'd guess the bottom
yeah 406 Master cylinder which will be mated up with my GTI-6 front brake setup.
i've just removed all the brake lines on the car as i'm renewing them with braided lines
ok so now i have 2 views LEFT or RIGHT ??
to be honest it don't matter, the only difference will be a very slight weight difference on say the middle of the spring depending weather you have mroe coils above or below the middle. But then again you got probably 400kg on each spring so your not going to notice it.
rssteve
The spring gets compressed from the bottom yes?????????????
So if you put the closer coils at the bottom they will bottom out before the top coils work to there full potential
Originally Posted by Alps Pacino
rssteve
Spiky
You/ve been out in the garage fucking about at this ungodly hour working on your car
yeah
and tomorrow i need to fit mt new clutch, clean the refit gearbox, then put the front suspension back on,
then fit the new brakes calipers,disc,pads
going to be a very busy day in the garage tomorrow
Originally Posted by Spiky
Originally Posted by cossiecrew
just do one of each
closer at the top it is then
How the fuck can it make any difference which way round they go
They are being compressed linearly so regardless of whether that compression is coming from the top or the bottom the effect will be exactly the same???
^Progressive spings, not linear, thats why they tighter wound and not the same throughout.
But they wont compress from the bottom up
Wont make much difference but id put them closer at bottom for the minute weight difference.
I understand that the spring rates are progressive i.e. it becomes harder to compress the springs the more they are compressed giving you good ride quality combined with good road holding (in very basic terms)
My point is that when you squeeze a spring you are performing a linear motion on it which is the same regardless of whether that force is coming from the top or bottom of the spring. Putting the tighter coils at the bottom or the top has no effect on the operation of the spring.
track.focus'd
Aug 12, 2015 05:53 PM
