Is this a S1 Turbo radiator?
Just a quickie -
I'm after a radiator for a S1 Turbo for a project I'm working on. I've found this one on Ebay
http://cgi.ebay.co.uk/escort-rs-tur...yphot ohosting
Is this the right rad? It doesn't look much narrower than a standard XR3i rad!
Mark
Mark
Here's a link that actually works! Perhaps it is the right one because the bracket does look different!
http://cgi.ebay.co.uk/ws/eBayISAPI.d...6622&rd=1&rd=1
xr3i - xr3 rad are different to a s1.... narrower in thickness...it has nothing to do with the intercooler.
by a recored one, your completey wasting your time with shite like that....its ok if its just a tempary fix to keep the car on the road, but thats false economy buying something in that condition.
rswoza - do you mean the cores themselves are narrower? The one on my XR3i is about an inch and a half thick - is the S1 thinner than that then?
I was planning to have it recored - that one does look in a sorry state. I'm just trying to check that it is the right one. It seems to have the mounting holes at the bottom for the Kenlowe though so does that mean it is?
Mark
Mark
Originally Posted by JesseT
What's wrong with a new XR3i rad? It's pretty much a straight fit and should be about 40£.
I had heard the S1 rads were a different size to the 3i ones before. Just need to get to the bottom of it really. I don't want to replace a perfectly good rad if it will do the job - just sounds like it won't.
And that is a S1 rad Mark
Thanks guys.
What about this little beauty? The pictures aren't as clear but the bracket seems to be further across as I would expect...
http://cgi.ebay.co.uk/Ford-Escort-1-...QQcmdZViewItem
Is this a S1 rad as well?
Mark
Mark
Lovely - so a final question before I part with my hard earned-
Can I make the nearly new 3i rad I've got fit by adjusting the brackets? Seems simple enough but if it really is too thick then I guess its not possible?
The XR3i rad fits nicely with the turbo and IC. Absolutely no problem.
Adam Graham
Sep 6, 2015 06:04 AM
