Symptom of bad engine tem sensor
Old Feb 16, 2007 | 03:05 PM
Butchi's Avatar
Butchi
Default Symptom of bad engine tem sensor
Does anybody know any symptoms of a bad engine temp sensor?
How the car goes when the temp sensor is brocken?
Mvh Buutchi
Old Feb 16, 2007 | 03:09 PM
3i_gaz's Avatar
3i_gaz
it dosent show how hot the coolant is, lol
Old Feb 16, 2007 | 04:22 PM
Wardy257's Avatar
Wardy257
Unplug it and see if it runs better. iIt only really help on start up and cold running.
Old Feb 16, 2007 | 05:37 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
If the sensor is saying "engine cold" all the time, it will run very rich...
Old Feb 16, 2007 | 06:21 PM
Butchi's Avatar
Butchi
I was thinking like this. The ecu box getting lot of info fron plenty of sensors.
If the rest of the sensors shoes the engine normal (warm) but the engine temp is brocken, the ecu probebly getting the wrong info and cannot work very good.
mvh butchi
Old Feb 17, 2007 | 09:29 AM
DazC's Avatar
DazC
If the sensor has failed closed circuit, it may think the engine is running at 120 degrees celcius!
If it fails open, it will run really rich and would probably be very difficult to drive. It will probably also black smoke.
Old Feb 17, 2007 | 09:53 AM
SaqsS2turbo's Avatar
SaqsS2turbo
dose that give problems of starting if cold cos my rst cranks for atleast 9 - 11 seconds then when its warm at a certain temp it wil start on the key then after it gose back to the same cud this be the temp sensor?
manuel boeckx
13
Oct 3, 2015 02:29 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
