starting problem ...
Old Feb 15, 2007 | 10:10 PM
SaqsS2turbo's Avatar
SaqsS2turbo
Default starting problem ...
right my rst takes about 9 - 11 seconds to crank and then it starts after a little warm up starts straight away any one know why this is? or any sugestions?
advance thanks
Old Feb 15, 2007 | 11:01 PM
antony215's Avatar
antony215
Escort Rs Turbo
Have you got a fuse in the heated seat slot?? worth a try mine was like yours when it was cold i put a fuse in the heated seat slot and now it starts on the key everytime
Old Feb 15, 2007 | 11:05 PM
SaqsS2turbo
il have a quick look see give us a few mins worth a try
Old Feb 15, 2007 | 11:14 PM
SaqsS2turbo
my fuse was in i took it out and its starts fine now put it back in started cranking for ages again took out then kick start wots that heated seat fuse got to do with any thing? is it connected to ecu or?
wen i got the loom there was no fuse but i put one in thought some one took itout gues it was out for a reason
Old Feb 15, 2007 | 11:26 PM
antony215's Avatar
antony215
Escort Rs Turbo
It's got something to do with the fuel management i think but dont quote me on it as im not 100% sure all i know is when i put one in mine it started on the key and has done ever since
Old Feb 15, 2007 | 11:28 PM
SaqsS2turbo
rst loom is so silly urs worked wen put in myns fine wen pulled out wot the floof
Old Feb 15, 2007 | 11:32 PM
antony215's Avatar
antony215
Escort Rs Turbo
It is strange some people say to unplug the cold start valve if your cars hard to start and/or lumpy when first started when i done that mine wouldn't start at all but others have done it and it's cured there problem
Old Feb 15, 2007 | 11:33 PM
SaqsS2turbo
ok i think its got to go back in safe chav told me its for the fuel ecu opps
Old Feb 15, 2007 | 11:34 PM
antony215's Avatar
antony215
Escort Rs Turbo
I thought it was
Old Feb 15, 2007 | 11:37 PM
SaqsS2turbo
its bugging me
Old Feb 15, 2007 | 11:38 PM
antony215's Avatar
antony215
Escort Rs Turbo
Try unpluging the cold start valve see what happens
Old Feb 15, 2007 | 11:41 PM
SaqsS2turbo
same thing
Old Feb 15, 2007 | 11:45 PM
SaqsS2turbo
il have a mess around 2morro its late everyones gonna wake up some loud escort
Old Feb 15, 2007 | 11:46 PM
antony215's Avatar
antony215
Escort Rs Turbo
Whats the spark plugs like are there good or old that could make it hard to start first thing if there old.
Old Feb 15, 2007 | 11:49 PM
SaqsS2turbo
there the 3 stem ngk R ones brand new and new uprated leads safe chav sed it may be due to not having a setup so i think il start savign up
Old Feb 15, 2007 | 11:54 PM
antony215's Avatar
antony215
Escort Rs Turbo
Could need a good set up if it aint been done for a while always good to have it checked on the RR any way
Old Feb 15, 2007 | 11:57 PM
SaqsS2turbo
yh basically ive just got the engine loom and ecu from a unfinished rst van the engines had alot done to it ported head bigger forged pistons etc it had a cossie turbo on it but was gone so i used my rst t3 so i i really do think it was never setup
Old Feb 16, 2007 | 12:04 AM
antony215's Avatar
antony215
Escort Rs Turbo
I think it's best you get it done then
Old Feb 16, 2007 | 12:05 AM
SaqsS2turbo
i think so to
mk22door
49
Mar 26, 2022 07:15 AM
muffster
13
Sep 3, 2015 09:40 PM
Bailes1992
Aug 16, 2015 07:14 PM
ginger1979
Jul 31, 2015 09:56 PM
