Cam Sensors for an EFi RST?
Old Feb 15, 2007 | 03:43 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Default Cam Sensors for an EFi RST?
Ok guys, I need a cam sensor and bracket for the RS. Who out there makes a good quality set up, and can do it ASAP? And of course, if anybody has pictures of these that would be superb.
Thank you
Old Feb 15, 2007 | 04:42 PM
SafeChav's Avatar
SafeChav
There are CVH's around that had sequential injection from the factory and as such have a cam phase sensor built into the head where the fuel pump blank plate is.
You could probably use one of these although you would have to have your cam machined and modified to accomodate the sensor.
Thats my 2p's worth if you don't like it then its tough
Old Feb 15, 2007 | 08:37 PM
Mixja's Avatar
Mixja
420
heres mine...
couldnt tell ya who made it tho as it came with the head, sorry!!!
Old Feb 15, 2007 | 08:58 PM
SafeChav's Avatar
SafeChav
dont think ive ever seen such a spanking head
Where did you get that set up from? Presumably you have to machine the teeth on the standard pulley slightly yea?
Old Feb 15, 2007 | 09:15 PM
Mixja's Avatar
Mixja
420
its a virgin head, never been run, built to rally x spec i believe, its cast at 0.75 over instead of the usual .50. been worked to stage 4, stainless steel sodium filled oversize valves, cvh35 with a/p lifters and isky double strength valve springs blah blah blah!!! its a wrc cam sensor and bracket iirc...
Old Feb 15, 2007 | 09:16 PM
SafeChav's Avatar
SafeChav
wana sell it
Gota be worth 50 quid
Old Feb 15, 2007 | 09:17 PM
Mixja's Avatar
Mixja
420
nooooooooooooooooooooooooooooooo!!!
Old Feb 15, 2007 | 09:27 PM
Mixja's Avatar
Mixja
420
wouldnt have thought itd be worth that much anyway, them exhaust valveslook a bit dirty!!!
Old Feb 15, 2007 | 09:28 PM
SafeChav's Avatar
SafeChav
Fuckin wind up
Old Feb 15, 2007 | 09:33 PM
Mixja's Avatar
Mixja
420
sorry....
Old Feb 15, 2007 | 09:42 PM
SafeChav's Avatar
SafeChav
only playing with ya
we best stop anyway other wise Tony will start moaning at me saying im threah hijacking
Old Feb 15, 2007 | 09:45 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I saw 10 replies and thought there might be something here worth reading!!!
Nice head though Mixja.
Old Feb 15, 2007 | 09:46 PM
Mixja's Avatar
Mixja
420
Old Feb 15, 2007 | 09:47 PM
SafeChav's Avatar
SafeChav
Everything i write is worth reading
Old Feb 15, 2007 | 09:50 PM
DazC's Avatar
DazC
But only to some one who suffers from downs sydrome!
Old Feb 15, 2007 | 09:51 PM
DazC's Avatar
DazC
Actually, thats being a bit nasty to the mentally handycapped. They are worth and deserve far more than your drivel!!
Old Feb 15, 2007 | 09:54 PM
Mixja's Avatar
Mixja
420
thanks!!
Old Feb 15, 2007 | 10:04 PM
Wardy257's Avatar
Wardy257
Why are you going sequential injection? It is a lot of hassle for no performance gains. Are you just doing your bit for the environment?
You dont need to take the signal off the cam itself. A metal bolt on the the front pulley and an inductive pulse sensor will work perfectly.
Old Feb 15, 2007 | 10:26 PM
SafeChav's Avatar
SafeChav
He himself didnt mention anything about sequential injection that was me. I dont even know what management he runs at present?
Old Feb 15, 2007 | 10:56 PM
Wardy257's Avatar
Wardy257
I can not really think of another reason to have a cam phase sensor though
Old Feb 15, 2007 | 10:59 PM
SafeChav's Avatar
SafeChav
If say he was on FRST management he may want it to upgrade to cossie management, which is better all day long
Old Feb 15, 2007 | 11:29 PM
Christian and Beccy
#1 in Spelling Club
Not by much though.
Sequential injection has alot of benefits in terms of driveability, when the management is advanced enough to make full use of it.
Old Feb 15, 2007 | 11:37 PM
EssexMikeSi's Avatar
EssexMikeSi
i duno if this is what ya looking for but heres pic of my efi converted rst running cossie m-ment. U can see the top sensor and top pulley there and bracket
Old Feb 16, 2007 | 08:21 AM
Christian and Beccy
#1 in Spelling Club
Mike, where did you get that?
Old Feb 16, 2007 | 12:11 PM
CliffRS4's Avatar
CliffRS4
Tony,
The man you want to speak to is Gadget as he did a real nice setup on my cam sensor. None of this wire poking out the top and curved.
It was a proper bracket with a nice detachable plug. I'll see if I can dig a pic out for you later on as it really is a nice bit of kit.
The Field motorsport cam sensor setup is pretty trick too.
Gus had one on his and may still do.
Old Feb 16, 2007 | 01:43 PM
zetec-turbo's Avatar
zetec-turbo
thats one of Jano's brackets Christian
Old Feb 16, 2007 | 02:19 PM
Christian and Beccy
#1 in Spelling Club
Thought so.
Old Feb 16, 2007 | 04:27 PM
Puss2's Avatar
Puss2
Formerly know as Puss
Heres mine that gadget made
Old Feb 16, 2007 | 04:33 PM
Christian and Beccy
#1 in Spelling Club
I don't think Gadget makes them anymore.
Old Feb 16, 2007 | 04:40 PM
gus's Avatar
gus
here is mine......
Old Feb 16, 2007 | 04:53 PM
Puss2's Avatar
Puss2
Your right he doesnt do them anymore he asked me for those pictures cause he couldnt remember what his ones looked like
Old Feb 16, 2007 | 04:57 PM
Gadget's Avatar
Gadget
Spanner monkey
Mixja, Thats one of mine
No facilities to make them anymore though!
Janno does them off the shelf i'm sure, as does Tommy field!
Tony, did you not get anyone to copy the diagram i e mailed you?
Old Feb 16, 2007 | 05:02 PM
Mixja's Avatar
Mixja
420
nice bit of kit mate...
Old Feb 16, 2007 | 07:49 PM
Tony Turbo's Avatar
Tony Turbo
No, not yet
I guess I should have shouldn't I? lol
I will see what I can do about taking it somewhere and getting it made up. I don't have the time in the week which is a bit annoying.
Thanks to everyone that has posted pictures and some sensible replys
Old Feb 16, 2007 | 09:53 PM
Christian and Beccy
#1 in Spelling Club
Now you just need to learn to spell.
It's REPLIES.
Old Feb 16, 2007 | 10:00 PM
StephenC's Avatar
StephenC
..BS Motorsport..
didnt the one that gus has get pictured in pf on a car, not sure if it was his car or not but the bracket was clearly cracked where it meets the rocker cover. Potential weekness in the design??? looks like a difficult thing to get looking neat and factory.
Old Feb 17, 2007 | 10:29 AM
gus's Avatar
gus
yeah that was tom scarlets one
not sure what happened there, was easily sorted thou
mine has been on for ages without trouble
Old Feb 18, 2007 | 09:36 AM
Tony Turbo's Avatar
Tony Turbo
So who out there can supply me with a cam sensor set up?
Old Feb 18, 2007 | 11:50 AM
M K's Avatar
M K
i run the same FMS set up as gus never had problems with mine cracking
Old Feb 18, 2007 | 11:54 AM
gus's Avatar
gus
tony im not sure if i will be using mine now
i will speak to fields and if not you can have it (if you want that is)
