Can you move dial up connections from 2000 to XP.
Old Feb 15, 2007 | 03:23 PM
L33 BYT's Avatar
L33 BYT
Default Can you move dial up connections from 2000 to XP.
Its because I have around 200 for my customers. I need to move them from my desktop to laptop for home support.
Old Feb 15, 2007 | 05:14 PM
DanRSturbo's Avatar
DanRSturbo
I'm not sure, in windows 2000 are the dial up networking connections listed under network connections ? can you copy it onto a floppy or usb drive ? Or even copy them across the network onto the laptop ?
Old Feb 16, 2007 | 07:10 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
no idea be interested to know what happens if you try it
Old Feb 16, 2007 | 12:24 PM
SoimaFreak's Avatar
SoimaFreak
try looking in the registry, not sure where mind you but the details are probably their, in which case you should be able to just export them to a .reg file copy/paste then double click on the XP machine, although this does depend on how the registry changed in 2000 -> xp
http://www.windowsbbs.com/showthread.php?t=49888
good luck
Old Mar 3, 2007 | 06:17 PM
L33 BYT's Avatar
L33 BYT
If you copy to the desktop or another media. It creates a shortcut only.
As said i have around 200 but if I search the registry under Remote Acess it only shows around 5
Old Mar 14, 2007 | 05:08 PM
BigMouthBillyBass's Avatar
BigMouthBillyBass
does USMT do it???
http://www.microsoft.com/downloads/d...displaylang=en
Similar sort of thing to XP's files and settings wizard, it's worth a go
gambo08
Feb 4, 2016 10:49 PM
Mark RS
Oct 12, 2015 06:01 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
little bram
Sep 27, 2015 07:45 AM
