400+ BHP Harvey Gibbs Engine... £3500 ono... Price Drop...
Old Feb 13, 2007 | 10:33 PM
FletchCossie's Avatar
FletchCossie
Default 400+ BHP Harvey Gibbs Engine... £3500 ono... Price Drop...
Engine was built by SCS (01733 576 614 - Harvey Gibbs) as one of their renown 400+ Horse Power engine conversions. It was built using a new 200 block & live Mapped on the engine dyno by Ahmed Bajoo. (If you wish to speak with Harvey ask about Jason Brown's mallard green Escort Cosworth without the whale tail.)
Power: 414hp
Torque: 404lb ft
Engine covered approximately 20,000 miles.
Bottom end:
200 block Machined oil ways & piston oil sprays
6 long studs (ARP Stud & Nut Kit)
Fully lightened & balanced (crank, rods, flywheel, pulleys etc)
Forged Cosworth pistons (standard size)
7.56:1 compression ratio
Crank grind unknown - possible .25/.25 (mains/bigends)
Cylinder head:
Matched Escort Cosworth Inlet Manifold
Ported & polished
Light Gasflowing
Isky valve springs
SCS spec cams
400 ice blue injectors
4wd exhaust manifold.
L8 400hp chip (Live Mapped Ahmed Bajoo)
Multilayered Head Gasket
Turbocharger:
T34 hybrid turbo
.55 motorsport exhaust housing
7 degree cut back blades
Gas flowed compressor housing
360 degree thrust bearing
The engine comes WITH Cylinder Head, 200 Block, Inlet Manifold, Exhaust Manifold, Ice Blue Injectors, T34 Turbo (inc. .55 Housing and actuator), L8 Management Chip, and Distributor. (I may of missed some off this list)
The Engine does NOT come with Clutch, alternator, starter motor, cam cover, Ignition leads, fuel rail, Sump and Diff. (I may of missed some off this list)
I have replaced the Cam Belt, Water Pump and All Hydraulic Lifters. Also oil has been changed around 6 times since I have brought the car and have only covered 8000miles.
I am looking for £4500 for the engine as it has been very good since I purchased it. Please contact me (Steve) on f-b-motorsport@hotmail.co.uk or via phone on 07732 872 122 for more details.
Old Mar 7, 2007 | 06:27 PM
FletchCossie
PRICE REDUCED TO £3500 before I put it on EBAY...
Old Mar 7, 2007 | 10:00 PM
FletchCossie
Not sure yet Dave, Im trying my hand at the bodywork over the next few months. When the bodyworks all sorted I will decide if to put a bigger bhp engine in or put it back to standard and sell it!
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Marv888
Sep 26, 2015 03:44 PM
