YB Crank Sensor
Old Feb 13, 2007 | 12:00 PM
WD Pro's Avatar
WD Pro
Default YB Crank Sensor
Can I cut the two metal tabs of it or does it use them for earthing ?
Cheers,
WD
Old Feb 14, 2007 | 03:04 PM
You can cut them off, but it will delete the braid around the wires which is there to stop any electrical interference and it needs to be grounded through these tabs, so if you do this it may not run perfect if it picks up interference from other electrical components, best leave it in place, as meatal sheilding is a defo good idea, particularly as it runs so close to dizzy.
Old Feb 15, 2007 | 11:54 AM
WD Pro's Avatar
WD Pro
Thanks, I will leave one of the tabs on and earth it then.
Cheers,
WD
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
