boost
Old Feb 13, 2007 | 09:43 AM
r-s-turbo's Avatar
r-s-turbo
Default boost
ive just fitted a -31 actuator as my standard one woz fucked n holding like 3 psi which was pants!
anyhow this -31 keeps peakin at like 10psi sumtimes abit more but only in like 4th n 5th on the motorway n i jus back off immediatly and it keeps hittin a flatspot but the thing is it didnt when i 1st put it on it was rapid! wen i first fitted this -31 it was well fast n ther woz no flatspot (yes i no i shud have had it setup, doin it this weekend at weston).
anyhow at the mo if i spool it up slowly n plant my foot it boosts n there isnt always a flatspot, but if i plant my foot sumtimes its like hitting a wall the flatspot is. is this the fuelcut in the ecu? or have i got a fooked tps sensor? i think i jus need less boost tbf until ive had it setup properly but i jus dont understand how it woz boosting really well n now its jus not
Old Feb 13, 2007 | 04:47 PM
zippyobrien's Avatar
zippyobrien
hitting boost limit on peak boost,
if your having it set upo, may aswell chip it at same time and go for 14 psi
Old Feb 14, 2007 | 11:53 AM
MattyRST's Avatar
MattyRST
Sounds like you need to chip it, as its hitting the boost limiter as what zippyobrien states
Old Feb 14, 2007 | 06:06 PM
reded06RS's Avatar
reded06RS
defo need a chip i had same prob
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
