where does the oil go?
Both of the cossie's that i've owned have used oil, the current one a bit more than the first!
I know they all do it, but where is it most likely to come from, as in up through the rings or valve stem seals?
does anyone know?
does anyone know?
Mine still used lots of oil after I'd had new valves and guides, and a new turbo. So, in my case it must have been past the piston rings, because I've just had a bottom end rebuild and now it uses hardly any, like 1/10 of what it used before.
A drilled ring is a the ring surrounding the bearings through which the oil passes and gets consumed.
The ring is drilled with tiny holes to creat some BACKPRESSURE thus forcing oil back in, or rather pressure keeps it in to start with.
Small turbo escorts use less as they have tighter tolerances ie clearance between turbo bearings and shaft due to LIGHTER COMPONENTS PRODUCING less END FLOAT.
The shaft floats on a sea of oil(except roller bearing), but it is still a DOUBLE OVERHANG TURBO design.
The roller bearing is a much better design as it uses 1/4 of the enrgy to drive impellors etc as compared to traditional sleeve bearings.
sleeve bearings typically use 800 watts of power as opposed to 200 watts for ROLLER BEARING ones.
Shaft movement is massively less also, tests showed at 150,000rpm there was 0.025mm for the roller bearing compared with 0.13-0.25mm for the sleeve bearing.
BTW temps can excede 1000C in a turbo on a road car.
Originally Posted by cossie604
They magic it away from new hence why Ford saw fit to put a sticker on them all saying 'check oil level daily'
(26k miles, one owner)
Check oil daily will probably be stickered over every cat in the land from all manufacturers, it is so that they cannot be held liable for some muppet saying "you did not say to check the oil" when it seizes, probably aimed at USA where the sue sue sue culture is, PANASONIC were sued successfully when a ladies CAT died after she put it in her MICROWAVE, as instructions for it did not say you could not do this.
when the cossie was made ,the figure cosworth gave was ,the yb should use 1 litre if oil in 600 miles
this is quite normall,
most people see black/dark grey soot from them when they boot it......overfuelling!! go closed loop!
this is quite normall, most people see black/dark grey soot from them when they boot it......overfuelling!! go closed loop!
Closed loop drops out when you boot it, it is only an advantage depending on what sort of driving you do, long motorway stuff it would be ace round town it is going to be open cycle all the time.
STU's system very very good, if I did long miles on m/way I would defo have it, the man is excellent with his tuning stuff.
yep it does revert back to the original map on quick throttle movements, or throttle pos over 60% but the engine is sooo much cleaner internally it wont smoke so much when you boot it , , and there is no bore wash issues at idle, so the oil stays in better condition and lasts longer, doesnt loss viscosity as quickly due to contamination
Originally Posted by LukeT
Group A breather kit can stop a lot of oil loss!
when i floor the thing for like half an hour , the oil level is at min
i've made my own catch tank from the breather and when i get the oil back in there it's at max again
is that pure a bad breather system (original) or are my piston rings worn out ?
deathrider666
Sep 28, 2015 06:12 PM
