1 HOUR TO GO! *T38 Turbo and 'Swedish style' Plenum*
2Evos & 1 Escort Van :-)
1 hour left on Ebay!!!!
Due to extreme brokeness! Selling my MINT T38 and an unsed Swedish style plenum.
Pics:
Spec:
T38 Turbo built by Vince formerly from Universal Turbos (Now working at CR Engineering)
In MINT condition having only been used for around 3000 miles and being less than 1 year old - pics were taken tonight (12/2/07) and you can see how good this turbo is...
NO SMOKE
NO END FLOAT
NO DAMAGE TO THE BLADES (See pics)
Comes with a -31 Actuator set to run 28 psi, or around 400-440 bhp on a suitable Cossie engine.
The Turbo has 360 degree thrust bearing, and is based around a large Turbo Escort Cosworth T34, with a larger compressor wheel, modified compressor housing and .63 exhaust housing.
This turbo is an ideal compromise for people that want T34 punch with T4 power - it gives the right mix of both. Ideal upgrade if you have gone to Stage 3 (350 ish bhp) and want that bit more.
Only selling as you always want more, and I've gone for a laggy T4 that should get me nearer 500 bhp
Plenum with throttle bracket:
Both items on Ebay, will not be ending early as I need to get back as much as I can reasonably get for them, due to being a skint fool!
Link to Plenum: http://cgi.ebay.co.uk/ws/eBayISAPI.d...6105&rd=1&rd=1
Item no is: 110091586105
Turbo link (Item no 110091582048) : http://cgi.ebay.co.uk/ws/eBayISAPI.d...2048&rd=1&rd=1
Si
Pics:
Spec:
NO SMOKE
NO END FLOAT
Si
i will let Sticky Paul know.
if he still needs one.
Mk2 could always do with a T38....you know you want it!
Si
Si i would have loved to have that turbo ect of you (after going out with you @ combe still got a big smile on my face from that day
) But im in the same boat and i think its starting to sink
Si i need a hose for a t34 to the air box in Blue have you got one in you spares as you wont need it now you gone T4
Originally Posted by abdr500
if only they had come sooner one of my coustomers would have broke your arm off the the inlet and turbo will tell him anyways
Timings never good where I'm concerned!
Si
You also need this Turbo in your life!!! Just like anyone with a T34 who fancies a smidge more Gee Gees!
Si
Si
Hose sounds good let me know
how much was it new Simon.
Realisitically it doesn't cost that much, but that is what this one owes me! Yikes!
I think you could buy one for approx £300 plus a T34 with large comp housing (ie not machined down in anyway, big air filter neck style)
I'll put the breakdown of what I spent up at a more normal time of day...
Si
£450 with 5 days left
£1500+
see how the auction goes.
Originally Posted by bud-weis
i'll swap your T4 if you want one Dave
plus a bit of pocket money for yourself
Si
Hose sounds good let me know Pic of the hose:
Have measured the ends - the big end is 70mm internal diameter, the other end is 66/67mm internal diameter.
Will that fit your air box?
It's £20 plus postage - £3 I'd say.
Si
Si
Si
Sounds good im sure it will fit the air box and if not i'll have to buy a K&N
How do you want the money Cash in the post or Paypal
Si
Si
Paypal suits me fine - it's:
sib666@hotmail.com
Make sure your address is on there and I'll post it off to you tomorrow
Cheers mucka
Si
Payment sent Si
Will post it Monday, should be with you within a couple of days. Muchly thanks!
Si
Aye, not bad at all. Happy with that. Finished on £720!
Plenum went for £195 too
Will help me get a bit more done on my engine build now.
Just gotta hope the money comes in next....
Si
Si
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
thought it would of sold for more than that though
