My S1 problem.STILL!!!!!!!
Feb 12, 2007 | 03:39 PM
ok peeps, i got the metering head out using a hammer, blood and brute force.
the good news is i have the replacement metering head on (
gup)
THE BAD.............
10 minutes to start her, doesnt smell of petrol now, no petrol fumes in the engine or from the exhaust....HOWEVER............
i still have the bloody misfire
so problem is still there...spark plugs,dizzy, ht leads, oil, boost pipes are all new.
any ideas why im still misfireing??
Rev counter sits nicley on 1000rpm doesnt jolt around the dial.
Feb 12, 2007 | 04:10 PM
when does the missfire happen?
Feb 12, 2007 | 04:24 PM
its constant as soon as you start it.
was told it was on cylinder 3...compression test was ok. They said to much fuel was being put in the engine and the metering unit would need replacing. Ive done that today but still have my misfire.
Feb 12, 2007 | 04:59 PM
swap injectors about? and see if its still on same cylinder?
might have a fucked injector mate
Feb 12, 2007 | 05:00 PM
beat me to it
Feb 12, 2007 | 05:01 PM
no fast yer last
Feb 12, 2007 | 06:45 PM
Feb 12, 2007 | 07:29 PM
gotta be an injecter then fella pull the plugs out and c the differant colours or the one thats wet
if that make sense fella
