EFI XR3I WHAT PARTS CAN I USE FOR EFI TURBO CONV
Old Feb 12, 2007 | 01:32 AM
ford crazy's Avatar
ford crazy
Default EFI XR3I WHAT PARTS CAN I USE FOR EFI TURBO CONV
PICKED UP A EFI XR3I
BEEN THINKING BOUT CHANGING TURBO OVER TO EFI
WHAT PARTS CAN USE OF XR3I
Old Feb 12, 2007 | 01:00 PM
SafeChav's Avatar
SafeChav
Pretty much all of it mate! The ECU won't be right obviously, and a few little odd bits and bobs but you've made life every easy to say the least
Old Feb 12, 2007 | 02:02 PM
ford crazy's Avatar
ford crazy
looked at a post other day and he was useing sierra parts cam timing and pullys i think will i still need them
Old Feb 12, 2007 | 02:11 PM
SafeChav's Avatar
SafeChav
Your EFI engine has all the parts you need, you would need to drill a 31mm hole in your block to accept the sensor though.
Old Feb 12, 2007 | 11:47 PM
Rick's Avatar
Rick
It depends WHICH efi system u want to run. If it's marelli, ur going to need to do a few mods...
Old Feb 13, 2007 | 02:58 PM
SafeChav's Avatar
SafeChav
Oh no............2 pin changes and a plug change
Whatever shall we do
Matt Baxter
Sep 16, 2015 08:30 PM
EoinXR3
Sep 7, 2015 05:44 AM
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 17, 2015 12:21 PM
marky_g
Aug 15, 2015 10:43 AM
