2.1 Zetec16v Turbo Alternator
Feb 11, 2007 | 10:23 PM
Im planning to run my 2.1 Zetec16v Turbo on fiesta efi ofab mangment i was just wondering which alternator should
i be useing my orignal one off my S1 or a later mondeo/escort efi one?
Martin
Feb 11, 2007 | 10:47 PM
the one off your s1 should be fine with the bracket thats on your engine
Feb 11, 2007 | 11:17 PM
What bracket are you going to run on the engine?
Feb 12, 2007 | 03:26 PM
I aint 100% sure i think its a 1.8 sierra one.
I bought the engine off
Red16 so i will stick with the S1 one as its not that old.
Feb 12, 2007 | 03:31 PM
Ah ok fair do's. The reason i asked was because if you were using a Series 2 bracket the Series 1 alternator won't fit.
Either should see you through fine, the later 70A one would be preferable though, but i run a 55A on my cabby with the biggest battery you could ever hope to fit in the tray and its fine
Feb 12, 2007 | 04:13 PM
SafeChav Top stuff dude i will maybe give you a shout back if i come unstuck converting my thing to Efi Ofab
Feb 12, 2007 | 04:35 PM
Feb 12, 2007 | 05:11 PM
Feb 12, 2007 | 10:57 PM
Quote:
i think its a mk3 bracket, could you post a pic up of your mk3 bracket so s1kid can double check?
Feb 12, 2007 | 11:03 PM
Unfortunately not mate, how do you think i learnt about it
The series 2 bracket has the adjuster arm bolted to it, the earlier arms bolt higher up the block, so if you have a MK4 water pump you have a bit of a problem
Feb 12, 2007 | 11:04 PM
How about you post up a picture of the bracket you have and i can I.D it for you
Feb 13, 2007 | 05:26 PM
The mk3 alternator sits much higher than in the mk4.
Feb 13, 2007 | 06:09 PM
Quote:
The alternators are different aswell though
Feb 13, 2007 | 08:15 PM
im just trying to help the lad
i dont have the engine
Feb 13, 2007 | 08:24 PM
Where in that response does it say "you" is "Red16"
Feb 13, 2007 | 09:33 PM
wanker
Feb 13, 2007 | 09:38 PM
wanker
Ave it slag
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
IanC
Sep 5, 2015 09:38 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
