amal valve ticking
hi!
thanks for your advices for my CO problem when idling
I have another prob :/
Before I start the car, the amal valve is ticking ("tick-tick-tick"
permanently like a relay)
When the car is running there is no prob
I tried to disconnect the amal valve for test, (I have an -36 or -34 garret actuator, I don't remember the number but it's 16psi actuator) In 4th gear at full throttle I have 0.4b ~6psi
Why ?
thanks !
Why ?
thanks !
Originally Posted by antony215
The amal valve should click when you first turn the car on but if it's doing it all the time then it maybe fucked.
As SafeChav say's if it's only clicking when you first turn the key then it's fine (it should click 2-3 times when you turn the key) if it's clicking all the time when the car is running then it's fucked
my ticking when I tun on ignition, but then ticking constantly but very silent.
but if my amal is fcuked, then he wouldnt work?but when I disconnect power suppy to amal valve I have only 0.3 bar but with amal valve with power on, I have 0.6. that means amal valve is good?
Originally Posted by Jack-of-all-Trades
thank you all for your answers
For me, my amalvalve is ticking a few before igniton then no more ticking
So you got your fuel problem sorted i presume? Is it running ok after the rebuild or not?
